GL doesnt work after increase disk
ERROR [VersionProbe] Unable to retrieve version from indexer node: Failed to connect to Connection refused.
Ubuntu 22.04.5 Jeamy/ GL Server 6.1 [GL running Opensearch instead]
(Error: [VersionProbe] Unable to retrieve version from Elasticsearch in a GL running Opensearch instead)
  • Package Version:
ERROR [VersionProbe] Unable to retrieve version from indexer node: Failed to connect to graylog001/127.0.1.1:9200. - Connection refused. 2024-10-31T15:41:46.718+02:00 INFO [VersionProbe] Indexer is not available. Retry #8 .
Close Could not load streams Loading streams failed with status: FetchError: There was an error fetching a resource: undefined. Additional information: Not available
erver currently unavailable We are experiencing problems connecting to the Graylog server running on
Pls help with come back GL to work
The error noted indicates that the OpenSearch deployment is experiencing a problem.
Log files created by the node(s) of the OpenSearch deployment will have error messages that reveal more details on the problem.
Once error messages being generated by OpenSearch that occur at the same (or similar) time(s) as the errors reported by Graylog have been identified, then focus on deciphering their meaning and what action(s) can be taken to resolve them.
Feel free to post here any further errors you find & aren’t certain of how to handle.
