I have my Graylog instance configured to Nginx proxy for external access.
My Nginx Code
location /Graylog/ {
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Graylog-Server-URL ExternalURL/Graylog/;
proxy_http_version 1.1;
rewrite ^/Graylog/(.*)$ /$1 break;
proxy_pass http://192.168.180.121:9000/;
In Graylog server.conf
http_external_uri = ExternalURL/Graylog/
Testing from the browser https://macweb.in/Graylog/
The Web UI loads able to login. When navigate to the menu options
Search / streams … the URL get change to the following
ExternalURL/Graylog/Graylog/search
ExternalURL/Graylog/Graylog/streams
Getting Page not found.
How to fix this issues.
dennis
(dennis)
February 25, 2025, 12:35pm
2
Hey @MacleanEbi ,
which Graylog version are you using? We have fixed related issues in 6.1.0.
if I need to upgrade to 6.1.0 is it a easy to upgrade.
As my current Graylog is in cluster node.
My backend is OpenSearch 2.x
Hey @MacleanEbi ,
Do incremental upgrades all the way up to 6.1, if you are doing a rolling upgrade start with the leader node first then move on to the subsequent nodes. At each upgrade make sure you are starting the service on the node checking the upgrade has been a success before moving on to the next node. Once all nodes are on the same version then begin the upgrade to the next incremental version on the leader node.
5.1 → 5.2 → 6.0 → 6.1
If you are Opensearch 2.x then you won’t need to upgrade anything there, Mongo 6 or 7 will all suffice.
@Wine_Merchant
Will do the incremental upgrade.
Once I upgrade to 6.1 the issue in the menu will be auto fix.
Or i need to do any config change
I’m not so sure, at a guess I would say this is the fix if you want further information.
dennis
(dennis)
March 10, 2025, 12:02pm
8
No need for any other config change, just updating Graylog should fix the issue.
system
(system)
Closed
March 24, 2025, 12:02pm
9
