Get "Remote Syslog Security Host" Logs from HPE Primera 600
Hello Guys I have a small problem. I want to monitor the HPE Primera 600 Storage.
Primera gives 2 types of logs. Security and non Security.
  • non Security need a UDP conection.
  • security need a TCP and TLS connection
I don’t know how to start. I deployed a Input (Syslog TCP) in the edit mask of the input i enabled TLS and put in the paths to the Graylog public and private key.
TLS is active in the server.conf of Graylog-Server.
In the Primera i put in
XXX cli% setsys RemoteSyslogSecurityHost test.graylog.org:1234
I can see that messages appear, but when I open the input in Graylog, the messages are not displayed.
When i start an Input (RAW TCP) on that port messages are displayed but only test messages from the system.
What else needs to be implemented? Where did I make a mistake?
Greetings
Is the certificate self signed, and does the HPE support untrusted certs?
I have an Idea. Is it possible that the cert have not the right key_usage?
usage:
keyUsage = keyEncipherment, dataEncipherment
extendedKeyUsage = serverAuth
It is a trusted cert and the root CA is trusted from the Primera
When you say you only see test messages on the raw input do you mean the mesaages that are sent to verify the setup (a test button on the setup page etc)
What do you mean by “I can see that messages appear”, where are you seeing this?
grafik
the counter for total I/O goes up and connections are listed
I created a short RAW TCP test input on that port and DONT enabled TCP.
I have deployed the Input!
Primera:
generate cert on the Primera for Syslog Client.
cli% createcert syslog-sec-client -csr -CN Primera.test.org -SAN DNS:Primera.test.org,IP:127.0.0.1
(name and IP are not real and have to be edited)
Install Ca-cert-Bundl
cli% importcert syslog-sec-client -ca stdin
CA-certified CERT import
cli% importcert syslog-sec-client stdi
Configuration for Remote Syslog Servers
cli% setsys RemoteSyslogSecurityHost graylog.test.org:1234
Start Service
cli% setsys RemoteSyslog 1
Graylog:
Deploy of Input Syslog TCP
Port:1234
TLS cert file:
/path/to/graylog TLS cert
TLS privat key:
/path/to/graylog TLS key
:ballot_box_with_check: Enable TLS
TLS client authentication
required
TLS Client Auth Trustet Certs
/path/to/Primera TLS genareted cert
You have to copy the generated cert from the Primera to your Graylog.
chown: graylog:graylog
chmod: 640
Greetings
Marvin
