I have added the GeoIP addon and added an extractor to separate out the IP address. However I still can’t get the GeoIP function to display the Map. Logs are stating that it is requiring latitude and longitude. Where should this be provided? Do I need to setup a GROK extractor?
I am using RHEL 6.9 and dumping everything to rsyslog
rsyslog-5.8.10.
Is this a problem with the version of rsyslog? Is there something else that I need to do?
2017-04-18T16:48:53.220Z ERROR [MapDataResource] Map data query failed: Invalid geo data term for field "Destinations": (required: <lat>,<lng> - example: 1.23,3.11)
2017-04-18T16:51:35.335Z ERROR [MapDataResource] Map data query failed: Invalid geo data term for field "Destinations": (required: <lat>,<lng> - example: 1.23,3.11
