Fresh 6.2 Install on Ubuntu 22.04 Unstable
Following single node installation instructions, I’ve got the server on an ESXi VM running Ubuntu 22.04 LTS. I setup an input for syslog udp and it will run for various amounts of times (minutes, hours, even a couple days) and then it’s breaking…
When I log in to the server all indexes are gone, the input I setup is gone and I get Internal Server Errors when trying to look at the Alerts or Streams page. Other than those errors, I’m not seeing anything in server.log and datanode.log that line up with it breaking.
In order to get it working again, I restart server service and it acts like a new install and takes me to the setup page for the datanode certs again. I also have to go into mongod and drop the index_field_types as it won’t start b/c of dup key errors.
Rinse/repeat. I’ve got over a week trying to get this stable/running. Twice I’ve started from a fresh VM. The second time the server ran for less than 20 minutes before bombing…
Any help would be appreciated. Can provide logs, etc. I’m just not seeing anything glaring in them..
Take a look at the mongod logs too:
/var/log/mongodb/mongod.log
It sounds like the database connection vanishes. Does the DB look normal afterwards? Is MongoDB on the same host as well?
