ubuntu@graylog:/etc/init.d$ /usr/bin/mongod --verbose --config /etc/mongod.conf &
[1] 18501
ubuntu@graylog:/etc/init.d$ 2020-09-22T09:07:35.364+0000 F CONTROL [main] Failed global initialization: FileNotOpen: Failed to open "/var/log/mongodb/mongod.log"
– Automatic restarting of the unit graylog-server.service has been scheduled, as the result for
– the configured Restart= setting for the unit.
Sep 22 16:25:56 graylog systemd[1]: Stopped Graylog server.
– Subject: Unit graylog-server.service has finished shutting down
– Defined-By: systemd
– Unit graylog-server.service has finished shutting down.
Sep 22 16:25:56 graylog systemd[1]: Started Graylog server.
– Subject: Unit graylog-server.service has finished start-up
– Unit graylog-server.service has finished starting up.
– The start-up result is RESULT.
Sep 22 16:25:59 graylog systemd[1]: graylog-server.service: Main process exited, code=exited, status=1/FAILURE
Sep 22 16:25:59 graylog systemd[1]: graylog-server.service: Failed with result ‘exit-code’.
Sep 22 16:26:09 graylog systemd[1]: graylog-server.service: Service hold-off time over, scheduling restart.
Sep 22 16:26:09 graylog systemd[1]: graylog-server.service: Scheduled restart job, restart counter is at 2269.
– Subject: Automatic restarting of a unit has been scheduled
Sep 22 16:26:09 graylog systemd[1]: Stopped Graylog server.
Sep 22 16:26:09 graylog systemd[1]: Started Graylog server.
Sep 22 16:26:12 graylog systemd[1]: graylog-server.service: Main process exited, code=exited, status=1/FAILURE
Sep 22 16:26:12 graylog systemd[1]: graylog-server.service: Failed with result ‘exit-code’.
Sep 22 16:26:22 graylog systemd[1]: graylog-server.service: Service hold-off time over, scheduling restart.
Sep 22 16:26:22 graylog systemd[1]: graylog-server.service: Scheduled restart job, restart counter is at 2270.
Sep 22 16:26:22 graylog systemd[1]: Stopped Graylog server.
Sep 22 16:26:22 graylog systemd[1]: Started Graylog server.
Sep 22 16:26:25 graylog systemd[1]: graylog-server.service: Main process exited, code=exited, status=1/FAILURE
Sep 22 16:26:25 graylog systemd[1]: graylog-server.service: Failed with result ‘exit-code’.
Sep 22 16:26:28 graylog sudo[3609]: ubuntu : TTY=pts/0 ; PWD=/var/lib/mongodb ; USER=root ; COMMAND=/bin/journalctl -xe
Sep 22 16:26:28 graylog sudo[3609]: pam_unix(sudo:session): session opened for user root by ubuntu(uid=0)
When I started mongod with specificly mentioned the DB path it seems to work.
But the db path is also mentioned in the conf file.
ubuntu@graylog:/var/log$ sudo mongod --dbpath /var/lib/mongodb
2020-09-22T17:44:04.771+0000 I CONTROL [initandlisten] MongoDB starting : pid=27733 port=27017 dbpath=/var/lib/mongodb 64-bit host=graylog
2020-09-22T17:44:04.771+0000 I CONTROL [initandlisten] db version v3.6.3
2020-09-22T17:44:04.771+0000 I CONTROL [initandlisten] git version: 9586e557d54ef70f9ca4b43c26892cd55257e1a5
2020-09-22T17:44:04.771+0000 I CONTROL [initandlisten] OpenSSL version: OpenSSL 1.1.1 11 Sep 2018
2020-09-22T17:44:04.771+0000 I CONTROL [initandlisten] allocator: tcmalloc
2020-09-22T17:44:04.771+0000 I CONTROL [initandlisten] modules: none
2020-09-22T17:44:04.772+0000 I CONTROL [initandlisten] build environment:
2020-09-22T17:44:04.772+0000 I CONTROL [initandlisten] distarch: x86_64
2020-09-22T17:44:04.772+0000 I CONTROL [initandlisten] target_arch: x86_64
2020-09-22T17:44:04.772+0000 I CONTROL [initandlisten] options: { storage: { dbPath: "/var/lib/mongodb" } }
2020-09-22T17:44:04.772+0000 I - [initandlisten] Detected data files in /var/lib/mongodb created by the 'wiredTiger' storage engine, so setting the active storage engine to 'wiredTiger'.
2020-09-22T17:44:04.772+0000 I STORAGE [initandlisten]
2020-09-22T17:44:04.772+0000 I STORAGE [initandlisten] ** WARNING: Using the XFS filesystem is strongly recommended with the WiredTiger storage engine
2020-09-22T17:44:04.772+0000 I STORAGE [initandlisten] ** See http://dochub.mongodb.org/core/prodnotes-filesystem
2020-09-22T17:44:04.772+0000 I STORAGE [initandlisten] wiredtiger_open config: create,cache_size=15544M,session_max=20000,eviction=(threads_min=4,threads_max=4),config_base=false,statistics=(fast),log=(enabled=true,archive=true,path=journal,compressor=snappy),file_manager=(close_idle_time=100000),statistics_log=(wait=0),verbose=(recovery_progress),
2020-09-22T17:44:04.996+0000 I STORAGE [initandlisten] WiredTiger message [1600796644:996498][27733:0x7fb91d5680c0], txn-recover: Main recovery loop: starting at 4/5376
2020-09-22T17:44:05.075+0000 I STORAGE [initandlisten] WiredTiger message [1600796645:75697][27733:0x7fb91d5680c0], txn-recover: Recovering log 4 through 5
2020-09-22T17:44:05.121+0000 I STORAGE [initandlisten] WiredTiger message [1600796645:121762][27733:0x7fb91d5680c0], txn-recover: Recovering log 5 through 5
2020-09-22T17:44:05.178+0000 I CONTROL [initandlisten]
2020-09-22T17:44:05.178+0000 I CONTROL [initandlisten] ** WARNING: Access control is not enabled for the database.
2020-09-22T17:44:05.178+0000 I CONTROL [initandlisten] ** Read and write access to data and configuration is unrestricted.
2020-09-22T17:44:05.178+0000 I CONTROL [initandlisten] ** WARNING: You are running this process as the root user, which is not recommended.
2020-09-22T17:44:05.178+0000 I CONTROL [initandlisten] ** WARNING: This server is bound to localhost.
2020-09-22T17:44:05.178+0000 I CONTROL [initandlisten] ** Remote systems will be unable to connect to this server.
2020-09-22T17:44:05.178+0000 I CONTROL [initandlisten] ** Start the server with --bind_ip <address> to specify which IP
2020-09-22T17:44:05.178+0000 I CONTROL [initandlisten] ** addresses it should serve responses from, or with --bind_ip_all to
2020-09-22T17:44:05.178+0000 I CONTROL [initandlisten] ** bind to all interfaces. If this behavior is desired, start the
2020-09-22T17:44:05.178+0000 I CONTROL [initandlisten] ** server with --bind_ip 127.0.0.1 to disable this warning.
2020-09-22T17:44:05.185+0000 I FTDC [initandlisten] Initializing full-time diagnostic data capture with directory '/var/lib/mongodb/diagnostic.data'
2020-09-22T17:44:05.186+0000 I NETWORK [initandlisten] waiting for connections on port 27017
@mveerdonk Check your Graylog logs which might help you to identify the cause of it. May I know is there any specific reason for install the 2.5 Graylog version not the latest one?
fixed the installation with latest versions of MongoDB, Elastic and graylog.
Services are running, but webgui of graylog is empty/not showing.
I see some errors/warning, but not sure if these are blocking…
> 020-10-01T06:45:55.089Z INFO [PeriodicalsService] Shutting down periodical [org.graylog2.indexer.fieldtypes.IndexFieldTypePollerPeriodical].
> 2020-10-01T06:45:55.089Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog2.indexer.fieldtypes.IndexFieldTypePollerPeriodical] complete, took <0ms>.
> 2020-10-01T06:45:55.090Z INFO [PeriodicalsService] Shutting down periodical [org.graylog.scheduler.periodicals.ScheduleTriggerCleanUp].
> 2020-10-01T06:45:55.090Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog.scheduler.periodicals.ScheduleTriggerCleanUp] complete, took <0ms>.
> 2020-10-01T06:45:55.090Z INFO [PeriodicalsService] Shutting down periodical [org.graylog.plugins.sidecar.periodical.PurgeExpiredSidecarsThread].
> 2020-10-01T06:45:55.090Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog.plugins.sidecar.periodical.PurgeExpiredSidecarsThread] complete, took <0ms>.
> 2020-10-01T06:45:55.090Z INFO [PeriodicalsService] Shutting down periodical [org.graylog.plugins.sidecar.periodical.PurgeExpiredConfigurationUploads].
> 2020-10-01T06:45:55.090Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog.plugins.sidecar.periodical.PurgeExpiredConfigurationUploads] complete, took <0ms>.
> 2020-10-01T06:45:55.090Z INFO [PeriodicalsService] Shutting down periodical [org.graylog.plugins.views.search.db.SearchesCleanUpJob].
> 2020-10-01T06:45:55.090Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog.plugins.views.search.db.SearchesCleanUpJob] complete, took <0ms>.
> 2020-10-01T06:45:55.090Z INFO [PeriodicalsService] Shutting down periodical [org.graylog.events.periodicals.EventNotificationStatusCleanUp].
> 2020-10-01T06:45:55.090Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog.events.periodicals.EventNotificationStatusCleanUp] complete, took <0ms>.
> 2020-10-01T06:45:55.090Z INFO [PeriodicalsService] Shutting down periodical [org.graylog.plugins.collector.periodical.PurgeExpiredCollectorsThread].
> 2020-10-01T06:45:55.090Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog.plugins.collector.periodical.PurgeExpiredCollectorsThread] complete, took <0ms>.
> 2020-10-01T06:45:55.090Z INFO [PeriodicalsService] Shutting down periodical [org.graylog.plugins.license.LicenseManagerPeriodical].
> 2020-10-01T06:45:55.090Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog.plugins.license.LicenseManagerPeriodical] complete, took <0ms>.
> 2020-10-01T06:45:55.090Z INFO [PeriodicalsService] Shutting down periodical [org.graylog.plugins.license.LicenseReportPeriodical].
> 2020-10-01T06:45:55.090Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog.plugins.license.LicenseReportPeriodical] complete, took <0ms>.
> 2020-10-01T06:45:55.091Z INFO [PeriodicalsService] Shutting down periodical [org.graylog.plugins.report.scheduler.ReportPeriodical].
> 2020-10-01T06:45:55.091Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog.plugins.report.scheduler.ReportPeriodical] complete, took <0ms>.
> 2020-10-01T06:45:55.091Z INFO [PeriodicalsService] Shutting down periodical [org.graylog.plugins.report.service.ChromeDriverCleanupPeriodical].
> 2020-10-01T06:45:55.091Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog.plugins.report.service.ChromeDriverCleanupPeriodical] complete, took <0ms>.
> 2020-10-01T06:45:55.094Z INFO [GracefulShutdownService] Initiate shutdown for <JobWorkerPool>
> 2020-10-01T06:45:55.095Z INFO [GracefulShutdownService] Finished shutdown for <JobWorkerPool>, took 0 ms
> 2020-10-01T06:45:55.098Z INFO [GracefulShutdownService] Initiate shutdown for <BrowserDriverService>
> 2020-10-01T06:45:55.098Z INFO [GracefulShutdownService] Finished shutdown for <BrowserDriverService>, took 0 ms
> 2020-10-01T06:45:55.101Z INFO [LookupDataAdapterRefreshService] Stopping 0 jobs
> 2020-10-01T06:45:55.109Z INFO [LogManager] Shutdown complete.
> 2020-10-01T06:45:55.161Z INFO [JournalReader] Stopping.
> 2020-10-01T06:45:58.178Z WARN [IndexFieldTypePollerPeriodical] Active write index for index set "Default index set" (5f757b024f5624007959fb5e) doesn't exist yet
> 2020-10-01T06:46:03.178Z WARN [IndexFieldTypePollerPeriodical] Active write index for index set "Default index set" (5f757b024f5624007959fb5e) doesn't exist yet
> 2020-10-01T06:46:08.178Z WARN [IndexFieldTypePollerPeriodical] Active write index for index set "Default index set" (5f757b024f5624007959fb5e) doesn't exist yet
> 2020-10-01T06:46:13.178Z WARN [IndexFieldTypePollerPeriodical] Active write index for index set "Default index set" (5f757b024f5624007959fb5e) doesn't exist yet
> 2020-10-01T06:46:18.178Z WARN [IndexFieldTypePollerPeriodical] Active write index for index set "Default index set" (5f757b024f5624007959fb5e) doesn't exist yet
> 2020-10-01T06:46:23.178Z WARN [IndexFieldTypePollerPeriodical] Active write index for index set "Default index set" (5f757b024f5624007959fb5e) doesn't exist yet
> 2020-10-01T06:46:25.101Z ERROR [ServerBootstrap] Unable to shutdown properly on time. {STOPPING=[BufferSynchronizerService [STOPPING], JobSchedulerService [STOPPING]], TERMINATED=[InputSetupService [TERMINATED], MongoDBProcessingStatusRecorderService [TERMINATED], UrlWhitelistService [TERMINATED], OutputSetupService [TERMINATED], StreamCacheService [TERMINATED], PeriodicalsService [TERMINATED], GracefulShutdownService [TERMINATED], ConfigurationEtagService [TERMINATED], LookupTableService [TERMINATED], EtagService [TERMINATED], KafkaJournal [TERMINATED], JournalReader [TERMINATED]], FAILED=[JerseyService [FAILED]]}
> 2020-10-01T06:46:25.101Z ERROR [ServerBootstrap] Graylog startup failed. Exiting. Exception was:
> java.lang.IllegalStateException: Expected to be healthy after starting. The following services are not running: {FAILED=[JerseyService [FAILED]]}
> at com.google.common.util.concurrent.ServiceManager$ServiceManagerState.checkHealthy(ServiceManager.java:773) ~[graylog.jar:?]
> at com.google.common.util.concurrent.ServiceManager$ServiceManagerState.awaitHealthy(ServiceManager.java:585) ~[graylog.jar:?]
> at com.google.common.util.concurrent.ServiceManager.awaitHealthy(ServiceManager.java:316) ~[graylog.jar:?]
> at org.graylog2.bootstrap.ServerBootstrap.startCommand(ServerBootstrap.java:161) [graylog.jar:?]
> at org.graylog2.bootstrap.CmdLineTool.run(CmdLineTool.java:210) [graylog.jar:?]
> at org.graylog2.bootstrap.Main.main(Main.java:50) [graylog.jar:?]
> Suppressed: com.google.common.util.concurrent.ServiceManager$FailedService: JerseyService [FAILED]
> Caused by: java.net.BindException: Cannot assign requested address
> at sun.nio.ch.Net.bind0(Native Method) ~[?:?]
> at sun.nio.ch.Net.bind(Net.java:461) ~[?:?]
> at sun.nio.ch.Net.bind(Net.java:453) ~[?:?]
> at sun.nio.ch.ServerSocketChannelImpl.bind(ServerSocketChannelImpl.java:227) ~[?:?]
> at sun.nio.ch.ServerSocketAdaptor.bind(ServerSocketAdaptor.java:80) ~[?:?]
> at org.glassfish.grizzly.nio.transport.TCPNIOBindingHandler.bindToChannelAndAddress(TCPNIOBindingHandler.java:131) ~[graylog.jar:?]
> at org.glassfish.grizzly.nio.transport.TCPNIOBindingHandler.bind(TCPNIOBindingHandler.java:88) ~[graylog.jar:?]
> at org.glassfish.grizzly.nio.transport.TCPNIOTransport.bind(TCPNIOTransport.java:238) ~[graylog.jar:?]
> at org.glassfish.grizzly.nio.transport.TCPNIOTransport.bind(TCPNIOTransport.java:218) ~[graylog.jar:?]
> at org.glassfish.grizzly.nio.transport.TCPNIOTransport.bind(TCPNIOTransport.java:209) ~[graylog.jar:?]
> at org.glassfish.grizzly.http.server.NetworkListener.start(NetworkListener.java:723) ~[graylog.jar:?]
> at org.glassfish.grizzly.http.server.HttpServer.start(HttpServer.java:277) ~[graylog.jar:?]
> at org.graylog2.shared.initializers.JerseyService.startUpApi(JerseyService.java:201) ~[graylog.jar:?]
> at org.graylog2.shared.initializers.JerseyService.startUp(JerseyService.java:147) ~[graylog.jar:?]
> at com.google.common.util.concurrent.AbstractIdleService$DelegateService$1.run(AbstractIdleService.java:62) ~[graylog.jar:?]
> at com.google.common.util.concurrent.Callables$4.run(Callables.java:119) ~[graylog.jar:?]
> at java.lang.Thread.run(Thread.java:834) ~[?:?]
> 2020-10-01T06:46:25.103Z ERROR [AuditLogger] Unable to write audit log entry because there is no valid license.
> 2020-10-01T06:46:25.104Z INFO [Server] SIGNAL received. Shutting down.
> 2020-10-01T06:46:25.106Z ERROR [AuditLogger] Unable to write audit log entry because there is no valid license.
> 2020-10-01T06:46:25.106Z INFO [GracefulShutdown] Graceful shutdown initiated.
> 2020-10-01T06:46:25.106Z INFO [GracefulShutdown] Node status: [Halting [LB:DEAD]]. Waiting <3sec> for possible load balancers to recognize state change.
> 2020-10-01T06:46:25.188Z WARN [IndexFieldTypePollerPeriodical] Active write index for index set "Graylog Events" (5f757b044f5624007959fc25) doesn't exist yet
> 2020-10-01T06:46:25.191Z WARN [IndexFieldTypePollerPeriodical] Active write index for index set "Graylog System Events" (5f757b044f5624007959fc28) doesn't exist yet
> 2020-10-01T06:46:28.178Z WARN [IndexFieldTypePollerPeriodical] Active write index for index set "Default index set" (5f757b024f5624007959fb5e) doesn't exist yet
> 2020-10-01T06:46:33.178Z WARN [IndexFieldTypePollerPeriodical] Active write index for index set "Default index set" (5f757b024f5624007959fb5e) doesn't exist yet
> 2020-10-01T06:46:38.178Z WARN [IndexFieldTypePollerPeriodical] Active write index for index set "Default index set" (5f757b024f5624007959fb5e) doesn't exist yet
> 2020-10-01T06:46:43.178Z WARN [IndexFieldTypePollerPeriodical] Active write index for index set "Default index set" (5f757b024f5624007959fb5e) doesn't exist yet
> 2020-10-01T06:46:48.178Z WARN [IndexFieldTypePollerPeriodical] Active write index for index set "Default index set" (5f757b024f5624007959fb5e) doesn't exist yet
> 2020-10-01T06:46:53.178Z WARN [IndexFieldTypePollerPeriodical] Active write index for index set "Default index set" (5f757b024f5624007959fb5e) doesn't exist yet
> 2020-10-01T06:46:55.109Z ERROR [Cluster] Couldn't read cluster health for indices [graylog_deflector, gl-events_deflector, gl-system-events_deflector]
> (n/a)
> 2020-10-01T06:46:55.110Z WARN [BufferSynchronizerService] Elasticsearch is unavailable. Not waiting to clear buffers and caches, as we have no healthy cluster.
> 2020-10-01T06:46:55.110Z ERROR [AuditLogger] Unable to write audit log entry because there is no valid license.
> 2020-10-01T06:46:55.110Z INFO [OutputSetupService] Stopping output org.graylog2.outputs.BlockingBatchedESOutput
> 2020-10-01T06:46:55.111Z INFO [GracefulShutdown] Goodbye.
> 2020-10-01T06:46:58.178Z WARN [IndexFieldTypePollerPeriodical] Active write index for index set "Default index set" (5f757b024f5624007959fb5e) doesn't exist yet
> 2020-10-01T06:47:03.178Z WARN [IndexFieldTypePollerPeriodical] Active write index for index set "Default index set" (5f757b024f5624007959fb5e) doesn't exist yet
> 2020-10-01T06:47:08.178Z WARN [IndexFieldTypePollerPeriodical] Active write index for index set "Default index set" (5f757b024f5624007959fb5e) doesn't exist yet
> 2020-10-01T06:47:13.178Z WARN [IndexFieldTypePollerPeriodical] Active write index for index set "Default index set" (5f757b024f5624007959fb5e) doesn't exist yet
> 2020-10-01T06:47:18.177Z WARN [IndexFieldTypePollerPeriodical] Active write index for index set "Default index set" (5f757b024f5624007959fb5e) doesn't exist yet
> 2020-10-01T06:47:23.177Z WARN [IndexFieldTypePollerPeriodical] Active write index for index set "Default index set" (5f757b024f5624007959fb5e) doesn't exist yet
> 2020-10-01T06:47:25.187Z WARN [IndexFieldTypePollerPeriodical] Active write index for index set "Graylog Events" (5f757b044f5624007959fc25) doesn't exist yet
> 2020-10-01T06:47:25.189Z WARN [IndexFieldTypePollerPeriodical] Active write index for index set "Graylog System Events" (5f757b044f5624007959fc28) doesn't exist yet
> 2020-10-01T06:47:28.178Z WARN [IndexFieldTypePollerPeriodical] Active write index for index set "Default index set" (5f757b024f5624007959fb5e) doesn't exist yet
> 2020-10-01T06:47:33.178Z WARN [IndexFieldTypePollerPeriodical] Active write index for index set "Default index set" (5f757b024f5624007959fb5e) doesn't exist yet
ubuntu@graylog:/var/log/graylog-server$ sudo systemctl status graylog-server.service
Loaded: loaded (/usr/lib/systemd/system/graylog-server.service; enabled; vendor preset: enabled)
Active: active (running) since Thu 2020-10-01 07:33:36 UTC; 14s ago
Docs: http://docs.graylog.org/
Main PID: 10160 (graylog-server)
Tasks: 106 (limit: 4915)
CGroup: /system.slice/graylog-server.service
├─10160 /bin/sh /usr/share/graylog-server/bin/graylog-server
└─10192 /usr/bin/java -Xms1g -Xmx1g -XX:NewRatio=1 -server -XX:+ResizeTLAB -XX:+UseConcMarkSweepGC -XX:+CMSConcurrentMTEnabled -XX:+CMSClassUnloadingEnabled
Oct 01 07:33:36 graylog systemd[1]: Started Graylog server.
Oct 01 07:33:36 graylog graylog-server[10160]: Java HotSpot(TM) 64-Bit Server VM warning: Option UseConcMarkSweepGC was deprecated in version 9.0 and will likely be rem
Oct 01 07:33:37 graylog graylog-server[10160]: WARNING: sun.reflect.Reflection.getCallerClass is not supported. This will impact performance.
Oct 01 07:33:38 graylog graylog-server[10160]: WARNING: An illegal reflective access operation has occurred
Oct 01 07:33:38 graylog graylog-server[10160]: WARNING: Illegal reflective access by com.google.inject.assistedinject.FactoryProvider2$MethodHandleWrapper (file:/usr/sh
Oct 01 07:33:38 graylog graylog-server[10160]: WARNING: Please consider reporting this to the maintainers of com.google.inject.assistedinject.FactoryProvider2$MethodHan
Oct 01 07:33:38 graylog graylog-server[10160]: WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
Oct 01 07:33:38 graylog graylog-server[10160]: WARNING: All illegal access operations will be denied in a future release
after this change everything is running. In elastic log I don’t see any errors.
My graylog server.log
2020-10-01T15:12:22.663+02:00 ERROR [ServerBootstrap] Unable to shutdown properly on time. {STOPPING=[JobSchedulerService [STOPPING]], TERMINATED=[InputSetupService [TERMINATED], MongoDBProcessingStatusRecorderService [TERMINATED], UrlWhitelistService [TERMINATED], StreamCacheService [TERMINATED], LookupTableService [TERMINATED], GracefulShutdownService [TERMINATED], PeriodicalsService [TERMINATED], OutputSetupService [TERMINATED], ConfigurationEtagService [TERMINATED], EtagService [TERMINATED], KafkaJournal [TERMINATED], BufferSynchronizerService [TERMINATED], JournalReader [TERMINATED]], FAILED=[JerseyService [FAILED]]}
2020-10-01T15:12:22.663+02:00 ERROR [ServerBootstrap] Graylog startup failed. Exiting. Exception was:
2020-10-01T15:12:22.670+02:00 INFO [Server] SIGNAL received. Shutting down.
2020-10-01T15:12:22.675+02:00 INFO [GracefulShutdown] Graceful shutdown initiated.
2020-10-01T15:12:22.675+02:00 INFO [GracefulShutdown] Node status: [Halting [LB:DEAD]]. Waiting <3sec> for possible load balancers to recognize state change.
2020-10-01T15:12:26.678+02:00 INFO [GracefulShutdown] Goodbye.
