Filebeat Collector Sidecar: How to override collector_node_id in config?
How to configure the Graylog collector sidecar to get a custom collector_node_id in the Filebeat configuration?
I am on Graylog Collector Sidecar version 0.1.6 and configured the collector sidecar node_name in:
/etc/graylog/collector-sidecar/collector_sidecar.yml
as
node_name: xxxx
but the generated config for filebeat
/etc/graylog/collector-sidecar/generated/filebeat.yml
uses the system hostname for collector_node_id:
filebeat:   prospectors:
  - encoding: plain
    exclude_files: []
    fields:
      collector_node_id: my-hostname-not-xxxx
Is it possible to force a collector_node_id to be set as xxxx instead?
