Default Sidecar collector in configuration? -- features request
Hi, Developers,
New to Graylog.
I managed to get a cluster of stateless CentOS 7 nodes installed with graylog-sidecar and filebeats. The feature I would like to have is a default sidecar collector when a new node joins, and persistent node-id:
Eg, when a node reboot, it will boot to the image, and start afresh, and it will rerun the graylog-sidecar -service install and get the new node-id. It will connect to the server, but with a new node-id, so I have to configure it to use the collector, it still shows two entries in the sidecar lists, they should be merged. I have 500+ stateless clients, when they all reboot, they are all treated new(new node-id). So two functions needed:
A: retain the node-id when a node-id file is polluted or lost,
B: ability to set a default sidecar collector config on the server, so nodes will work after reimaging and retained the logs.
I checked around briefly, but don’t find answers immediately. Apologies if I missed it.
Thanks,
Wei
  • OS Information: CentOS 7.9 3.10.0-1160.45.1.el7.x86_64
  • Package Version:
    graylog -4.2-repository-1-4.noarch
graylog -server-4.2.6-1.noarch
filebeat -8.0.0-1.x86_64
graylog -sidecar-1.1.0-1.x86_64
graylog -sidecar-repository-1-2.noarch
    NA
NA
Hello && Welcome @wei.guo
I was going to suggest something but realized you running a stateless environment. I see why you get a new node-id. Only thing I can suggest right now is to ask this question here.
Unless someone here has done this.
Thanks @gsmith. I will open an issue there.
