Filebeat Agent Compatibility Matrix
Hi everyone,
I have a question.
The Filebeat agent version that comes with Graylog 6.3 (Windows Server) and Sidecar is too old for productive use in my environment. It is version 8.9.0, built in July 2023 — so it’s already more than two years old.
Is there a compatibility matrix between Filebeat agents and Graylog?
And how about the latest Filebeat agents in the 9.x series — are they supported?
Or do we need to put Logstash in between to ensure full compatibility?
Thanks in advance,
Raphael
Hey @freebeasty1801
Work on implementing 9.x into Sidecar is underway, in the meantime you could try use 9.x by creating a new collector configuration and altering the executable path to account for a separate beats install.
