Feature request: Indirect expand
it would be nice to be able to expand logs using correlation id fields like traceId and etc
at the moment there is a feature “Show surrounding messages” and if correlation Id field name is set in the settings then it will show search results for traceId:X, but it would be great if there was another button that would open a new search with traceId:(a,b,…,z) where a,b,…,z are all unique traceIds from the current search results
Greetings! The best way to submit feature requests is via Issues · Graylog2/graylog2-server · GitHub
Thanks!
