Hello everyone,
For some time I have a problem of log recovery via rsyslog / syslog-ng.
Indeed my service syslog-ng does not launch correctly.
My goal is to recover the logs of a fortigate.
Do you have a solution to my problem?
Thank you very much.
Flo
SYSLOG-NG.CONF / IP of FORTIGATE : 217.XX.XX.XX
@version:3.5
@include "scl.conf"
# syslog-ng configuration file.
# This should behave pretty much like the original syslog on RedHat. But
# it could be configured a lot smarter.
# See syslog-ng(8) and syslog-ng.conf(5) for more information.
# Note: it also sources additional configuration files (*.conf)
# located in /etc/syslog-ng/conf.d/
options {
flush_lines (0);
time_reopen (10);
log_fifo_size (1000);
chain_hostnames (off);
use_dns (no);
use_fqdn (no);
create_dirs (no);
keep_hostname (yes);
source s_sys {
system();
internal();
tcp();
udp(network(ip(217.XX.XX.XX) port(11514));
destination d_local {
file("/var/log/Graylog/host$HOST.log" create_dirs(yes));
destination d_cons { file("/dev/console"); };
destination d_mesg { file("/var/log/messages"); };
destination d_auth { file("/var/log/secure"); };
destination d_mail { file("/var/log/maillog" flush_lines(10)); };
destination d_spol { file("/var/log/spooler"); };
destination d_boot { file("/var/log/boot.log"); };
destination d_cron { file("/var/log/cron"); };
destination d_kern { file("/var/log/kern"); };
destination d_mlal { usertty("*"); };
filter f_kernel { facility(kern); };
filter f_default { level(info..emerg) and
not (facility(mail)
or facility(authpriv)
or facility(cron)); };
filter f_auth { facility(authpriv); };
filter f_mail { facility(mail); };
filter f_emergency { level(emerg); };
filter f_news { facility(uucp) or
(facility(news)
and level(crit..emerg)); };
filter f_boot { facility(local7); };
filter f_cron { facility(cron); };
#log { source(s_sys); filter(f_kernel); destination(d_cons); };
log { source(s_sys); filter(f_kernel); destination(d_kern); };
log { source(s_sys); filter(f_default); destination(d_mesg); };
log { source(s_sys); filter(f_auth); destination(d_auth); };
log { source(s_sys); filter(f_mail); destination(d_mail); };
log { source(s_sys); filter(f_emergency); destination(d_mlal); };
log { source(s_sys); filter(f_news); destination(d_spol); };
log { source(s_sys); filter(f_boot); destination(d_boot); };
log { source(s_sys); filter(f_cron); destination(d_cron); };
log { source(s_sys); destination(d_local); };
# Source additional configuration files (.conf extension only)
@include "/etc/syslog-ng/conf.d/*.conf"
