Failed to send Telegram messages
Hi everyone, I am having some issues on sending alerts via telegram messages. Graylog gives error notifications like in the picture any suggestions?
Graylog is just showing you the error message from the Telegram API.
You are sending too many messages.
I understand this but i want to capture these messages no matter of their number
Maybe you can configure your alerts differently using aggregation, so you are batching up events.
Otherwise I think you need to either not use telegram; or manually buffer or batch your messages to reduce the rate of messages.
