Hi guys. We have some problems with the alert to a telegram.
I create a Definition with a query where i say - select level:3 AND device_name. Before I create stream rule with some regular expressions and check it on same window - they works!
So my questions: Need I choose Aggregation of results reaches a threshold or if I have results choose Filter has results ? And next in window Notifications what i have todo on field Grace Period and Message Backlog.
My tasks are this - when has a problem of our device has been - send a message from Stream of device and with a query in our Definitions settings to Telegram…
At now we have not see many alerted messages that has in graylog search stream…
Please help…
First read carefully documentation about alerts:
https://docs.graylog.org/en/3.1/pages/streams/alerts.html
If you want basic alerting, use Filter has result.
If you want only one message appear in notification, setup Message Backlog to 1.
