Extractor OR with same field parsing issue
If I use a grok pattern to extract this, only one pattern match on bar value.
To simplify my usecase, I use an example with only two messages with two field.
I’ve two messages:
source foo in bar
source foo as bar1
Grok pattern:
source %{BASE10NUM:fieldA}(( in %{NOTSPACE:fieldB})|( as %{NOTSPACE:fieldB}))
I’ve for the first message:
fieldA - foo
fieldB - bar
For the second:
fieldA - foo
Indeed, for the second, le “extractor worker” doesn’t parse the second fieldB item …
Now, if I try to reverse the condition as:
Grok pattern:
source %{BASE10NUM:fieldA}(( as %{NOTSPACE:fieldB})|( in %{NOTSPACE:fieldB}))
fieldA - foo
For the second:
fieldA - foo
fieldB - bar1
Information:
I know that with this example, the solution is source %{BASE10NUM:fieldA} (as|in) %{NOTSPACE:fieldB}. But my goal was to reproduce my output with more complex logs
Do you have an idea ?
please see this issue: https://github.com/Graylog2/graylog2-server/issues/4773
Oh, sorry I not seen it …
Thanks … waiting for the 3.0 stable, I use several extractors
