Dear All,
I have an extractor with wrong parsing.
I found a message what it wrong parsed, but how can I found the associate extractor?
Thanks,
Dear All,
Thanks,
you can’t - this is not possible.
The message itseld does not have the information attached what extractor has modified the message. With the processing pipelines you could add a field that holds the name of the rule that has modified the message, but with extractors this is not possible.
