Error with "message" and "source" fields
please support to solve this issue in viewing quick values and analise “message” and “source” fields
That is currently not an issue or error - that is a feature.
how can i adjust it to be viewed, as it was working normally before
I have found QuickValues for the source field extreme useful, for e.g. looking at all sources send logs, or a widget showing the efficiency of a load balancing setup for a selected subset of sources and a specific query.
As this feature has been removed, what would be the correct way to do it with 2.4.X (I have to adjust several dashboards after the upgrade).
I upgraded my test setup, and it seems that the source field should work as before, and message field does note have that option any more.
So the problem of the original poster could be about something elset?
Dears,
Please help me with my issue as I could previously view quick value figures for both message and source fields but after upgrading to v2.3x from v2.4x I faced administration issue with one of them and error with the other.
I already provided snapshot showing the 2 problems in one graph.
Any errors in the graylog’s or elasticsearch’s log files?
You can configure the Fields that are disabled for analysis in System > Configuration
Your Screenshot is not enough Information to help you in any way.
thanks for the provided snapshot that helped me with the “message” field administration issue.
But i still face the following errors when i click on the buttons of “Generate Chart” or “Quick Values”:
Updating field graph data failed: Error: cannot GET http://10.39.6.2:9000/api/search/universal/relative/fieldhistogram?query=*&range=0&interval=minute&field=message&cardinality=false (500)
Loading field graph for ‘message’ failed with status 500
without any more information - log messages for example from Graylog it is hard to tell what the reason is for that.
Forgive me as I’m not familiar enough with graylog.
If you could tell which logs to share I’ll do at once
we have covered the locations here: http://docs.graylog.org/en/stable/pages/configuration/file_location.html
the Graylog server.log would be needed information - at first.
