Error when searching in Graylog 4.3 with relative search
Hi all
We have a docker different images of Graylog running in two different environments. The latest was installed recently with next characteristics:
Graylog v4.3.8+8c4705e
MongoDB: 5.0
ElasticSearch: 7.10.2
In the older installation, when searching using the API with search/universal/relative and sort=asc we have a response from Graylog. The same search in the above version raised next message:
“type”: “ApiError”,
“message”: “Invalid sorting parameter: asc”
This was tested from REST API browser with the same behavior.
I’m not a native English speaker so it isn’t as perfect as I would like and, I don’t want to be rude in my first message but, for me it’s an error and I don’t know if you have it controlled.
Regards,
Javier
  • OS Information:
  • Package Version:
Hello && Welcome @fcojavier
Does this look like what you see?
So removing “asc” it seams to go through. :thinking:
This is kind of odd.
@fcojavier
I was to fast to post, I came across this here
What I seen was this section.
range==1800 sort==timestamp:asc limit==10000
So in the sort section of the API Browser I placed that in there.
What I completely missed was adding the field you need to → sort by.
Example: Source, timestamp, EventID, etc…
Thanks for the answer. Now I know something else about Graylog :slight_smile: and it is already fixed.
In Graylog v4.2.5+59802bf if you make sort=asc the request return values, that’s why we get an error when upgrading to Graylog v4.3.8+8c4705e.
This is the screenshot from version v4.2.5+59802bf
Thanks a lot,
Javier
