Hello, it’s my first post and my english is not god, so forgive me!
My problem is when i try run the graylog.jar.
When a try i’ve this error:
Error: A JNI error has occurred, please check your installation and try again
Exception in thread "main" java.lang.NoClassDefFoundError: org/bouncycastle/jce/provider/BouncyCastleProvider
at java.lang.Class.getDeclaredMethods0(Native Method)
at java.lang.Class.privateGetDeclaredMethods(Class.java:2729)
at java.lang.Class.privateGetMethodRecursive(Class.java:3076)
at java.lang.Class.getMethod0(Class.java:3046)
at java.lang.Class.getMethod(Class.java:1812)
at sun.launcher.LauncherHelper.validateMainClass(LauncherHelper.java:544)
at sun.launcher.LauncherHelper.checkAndLoadMain(LauncherHelper.java:526)
Caused by: java.lang.ClassNotFoundException: org.bouncycastle.jce.provider.BouncyCastleProvider
at java.net.URLClassLoader.findClass(URLClassLoader.java:382)
at java.lang.ClassLoader.loadClass(ClassLoader.java:418)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:352)
at java.lang.ClassLoader.loadClass(ClassLoader.java:351)
... 7 more
And do you have problem with compilation, or compilation worked fine, but graylog did not start. Which method do you use to start graylog? Systemd service?
You can still use precompiled graylog package from AUR:
