ERROR [VersionProbe] Unable to retrieve version from Elasticsearch node: Failed to connect to /127.0.0.1:9200. - Connection refused (Connection refused)
So I have updated my graylog server from 4.2.7 to 4.3.9 yesterday. Everything was working perfectly. Today when I started the server I get a “connection refused” when trying to access the UI.
I have looked at the logs and narrowed it down to this:
INFO  [VersionProbe] Elasticsearch is not available. Retry #1
ERROR [VersionProbe] Unable to retrieve version from Elasticsearch node: Failed to connect to /127.0.0.1:9200. - Connection refused (Connection refused).
INFO  [VersionProbe] Elasticsearch is not available. Retry #2
It goes on for a while. I have made sure that I have the correct version of elastic installed → elasticsearch-oss.x86_64 (7.10.2-1)
I have also googled this error, but mostly people experience this issue when running opensearch instead of elastic, that is not the case here.
I have tried setting this option in my server.conf file elastic_search_version = 7 but it didn’t solve the issue.
I’ve also made sure that this isn’t a firewall or a selinux issue, so now I really don’t know what to do.
My server.conf file:
is_master = true
password_secret = <super secret>
#root_username = admin
root_password_sha2 = <supersupersecret>
# Default is empty
#root_email = ""
# Default is UTC
#root_timezone = UTC
# Set the data directory here (relative or absolute)
# This directory is used to store Graylog server state.
# Default: data
# HTTP settings
#### HTTP bind address
# Default: 127.0.0.1:9000
http_bind_address = 192.168.100.45:9000
#### HTTP publish URI
#http_publish_uri = http://127.0.0.1:9000/
#### External Graylog URI
# Default: $http_publish_uri
#http_external_uri =
#### Enable CORS headers for HTTP interface
# This allows browsers to make Cross-Origin requests from any origin.
# This is disabled for security reasons and typically only needed if running graylog
# with a separate server for frontend development.
# Default: false
#http_enable_cors = false
#### Enable GZIP support for HTTP interface
# This compresses API responses and therefore helps to reduce
#http_enable_gzip = false
#http_max_header_size = 8192
# The size of the thread pool used exclusively for serving the HTTP interface.
#http_thread_pool_size = 16
# HTTPS settings
# Default: false
#http_enable_tls = true
# The password to unlock the private key used for securing the HTTP interface.
# requires authentication.
# Maximum number of retries to connect to elasticsearch on boot for the version probe.
# Default: 0, retry indefinitely with the given delay until a connection could be established
#elasticsearch_version_probe_attempts = 5
# Waiting time in between connection attempts for elasticsearch_version_probe_attempts
# Default: 5s
#elasticsearch_version_probe_delay = 5s
# Maximum amount of time to wait for successful connection to Elasticsearch HTTP port.
# Default: 10 Seconds
# (e. g. during search, index creation, or index time-range calculations)
# Default: 60 seconds
# be tore down.
# Default: 30s
# Set the default scheme when connecting to Elasticsearch discovered nodes
# Default: http (available options: http, https)
#elasticsearch_discovery_default_scheme = http
# Default: false
rotation_strategy = count
#            This configuration setting is only used on the first start of Graylog. After that,
#            index related settings can be changed in the Graylog web interface on the 'System / Indices' page.
#            Also see https://docs.graylog.org/docs/index-model#index-set-configuration
#  1w  = 1 week
#  1d  = 1 day
#  12h = 12 hours
# Optional upper bound on elasticsearch_max_time_per_index
# elasticsearch_max_write_index_age = 1d
#no_retention = false
retention_strategy = delete
elasticsearch_shards = 1
elasticsearch_replicas = 0
# Default: graylog-internal
# be enabled with care. See also: https://docs.graylog.org/docs/query-language
allow_highlighting = false
# Default: 1h
# Default: 20
# Mute the logging-output of ES deprecation warnings during REST calls in the ES RestClient
#elasticsearch_mute_deprecation_warnings = true
# Default: 1h
# Time interval for the job that runs index field type maintenance tasks like cleaning up stale entries. This doesn't
# need to run very often.
# Default: 1h
#index_field_type_periodical_interval = 1h
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
# The following settings (outputbuffer_processor_*) configure the thread pools backing each output buffer processor.
# See https://docs.oracle.com/javase/8/docs/api/java/util/concurrent/ThreadPoolExecutor.html for technical details
# When the number of threads is greater than the core (see outputbuffer_processor_threads_core_pool_size),
# this is the maximum time in milliseconds that excess idle threads will wait for new tasks before terminating.
# Default: 5000
# The number of threads to keep in the pool, even if they are idle, unless allowCoreThreadTimeOut is set
# Default: 3
# The maximum number of threads to allow in the pool
# Default: 30
# Possible types:
#  - yielding
#  - sleeping
#  - blocking
#  - busy_spinning
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
# Enable the message journal.
# The directory which will be used to store the message journal. The directory must be exclusively used by Graylog and
# ATTENTION:
# disabled if not set.
# messages end up.
#stale_master_timeout = 2000
#shutdown_timeout = 30000
# MongoDB connection string
# '+'-signs in the username or password need to be replaced by '%2B'
#mongodb_uri = mongodb://grayloguser:secret@localhost:27017,localhost:27018,localhost:27019/graylog?replicaSet=rs01
# DNS Seedlist https://docs.mongodb.com/manual/reference/connection-string/#dns-seedlist-connection-format
#mongodb_uri = mongodb+srv://server.example.org/graylog
# http://api.mongodb.com/java/current/com/mongodb/MongoOptions.html#threadsAllowedToBlockForConnectionMultiplier
# Email transport
#transport_email_enabled = false
#transport_email_hostname = mail.example.com
#transport_email_port = 587
#transport_email_use_auth = true
#transport_email_subject_prefix = [graylog]
# Encryption settings
# ATTENTION:
#    Using SMTP with STARTTLS *and* SMTPS at the same time is *not* possible.
# Use SMTP with STARTTLS, see https://en.wikipedia.org/wiki/Opportunistic_TLS
# Use SMTP over SSL (SMTPS), see https://en.wikipedia.org/wiki/SMTPS
# This is deprecated on most SMTP services!
#transport_email_use_ssl = false
# Default: 5s
#http_connect_timeout = 5s
# Default: 10s
#http_read_timeout = 10s
# Default: 10s
#http_write_timeout = 10s
# ATTENTION: If you configure a proxy, make sure to also configure the "http_non_proxy_hosts" option so internal
#            HTTP connections with other nodes does not go through the proxy.
# Examples:
#   - http://proxy.example.com:8123
#   - http://username:password@proxy.example.com:8123
#http_proxy_uri =
# A list of hosts that should be reached directly, bypassing the configured proxy server.
# This is a list of patterns separated by ",". The patterns may start or end with a "*" for wildcards.
# Any host matching one of these patterns will be reached through a direct connection instead of through a proxy.
# Examples:
#   - localhost,127.0.0.1
#   - 10.0.*,*.example.com
#http_non_proxy_hosts =
# Disable the optimization of Elasticsearch indices after index cycling. This may take some load from Elasticsearch
# on heavily used systems with large indices, but it will decrease search performance. The default is to optimize
# cycled indices.
#disable_index_optimization = true
# Optimize the index down to <= index_optimization_max_num_segments. A higher number may take some load from Elasticsearch
# on heavily used systems with large indices, but it will decrease search performance. The default is 1.
#index_optimization_max_num_segments = 1
# The threshold of the garbage collection runs. If GC runs take longer than this threshold, a system notification
# will be generated to warn the administrator about possible problems with the system. Default is 1 second.
#gc_warning_threshold = 1s
# Connection timeout for a configured LDAP server (e. g. ActiveDirectory) in milliseconds.
# Disable the use of a native system stats collector (currently OSHI)
disable_native_system_stats_collector = true
# The default cache time for dashboard widgets. (Default: 10 seconds, minimum: 1 second)
# For some cluster-related REST requests, the node must query all other nodes in the cluster. This is the maximum number
# of threads available for this. Increase it, if '/cluster/*' requests take long to complete.
# Should be http_thread_pool_size * average_cluster_size if you have a high number of concurrent users.
# The server is writing processing status information to the database on a regular basis. This setting controls how
# often the data is written to the database.
# Default: 1s (cannot be less than 1s)
#processing_status_persist_interval = 1s
# Configures the threshold for detecting outdated processing status records. Any records that haven't been updated
# in the configured threshold will be ignored.
# Default: 1m (one minute)
#processing_status_update_threshold = 1m
# Configures the journal write rate threshold for selecting processing status records. Any records that have a lower
# one minute rate than the configured value might be ignored. (dependent on number of messages in the journal)
# Default: 1
#processing_status_journal_write_rate_threshold = 1
# Configures the prefix used for graylog event indices
# Default: gl-events
#default_events_index_prefix = gl-events
# Configures the prefix used for graylog system event indices
# Default: gl-system-events
#default_system_events_index_prefix = gl-system-events
# Automatically load content packs in "content_packs_dir" on the first start of Graylog.
#content_packs_loader_enabled = false
# The directory which contains content packs which should be loaded on the first start of Graylog.
#content_packs_dir = data/contentpacks
# A comma-separated list of content packs (files in "content_packs_dir") which should be applied on
# the first start of Graylog.
# Default: empty
#content_packs_auto_install = grok-patterns.json
# The allowed TLS protocols for system wide TLS enabled servers. (e.g. message inputs, http interface)
# Setting this to an empty value, leaves it up to system libraries and the used JDK to chose a default.
# Default: TLSv1.2,TLSv1.3  (might be automatically adjusted to protocols supported by the JDK)
#enabled_tls_protocols= TLSv1.2,TLSv1.3
# Enable Prometheus exporter HTTP server.
# Default: false
#prometheus_exporter_enabled = false
# IP address and port for the Prometheus exporter HTTP server.
# Default: 127.0.0.1:9833
#prometheus_exporter_bind_address = 127.0.0.1:9833
# Path to the Prometheus exporter core mapping file. If this option is enabled, the full built-in core mapping is
# replaced with the mappings in this file.
# This file is monitored for changes and updates will be applied at runtime.
# Default: none
#prometheus_exporter_mapping_file_path_core = prometheus-exporter-mapping-core.yml
# Path to the Prometheus exporter custom mapping file. If this option is enabled, the mappings in this file are
# configured in addition to the built-in core mappings. The mappings in this file cannot overwrite any core mappings.
# Default: none
#prometheus_exporter_mapping_file_path_custom = prometheus-exporter-mapping-custom.yml
# Configures the refresh interval for the monitored Prometheus exporter mapping files.
# Default: 60s
#prometheus_exporter_mapping_file_refresh_interval = 60s
# Optional allowed paths for Graylog data files. If provided, certain operations in Graylog will only be permitted
# if the data file(s) are located in the specified paths (for example, with the CSV File lookup adapter).
# All subdirectories of indicated paths are allowed by default. This Provides an additional layer of security,
# and allows administrators to control where in the file system Graylog users can select files from.
#allowed_auxiliary_paths = /etc/graylog/data-files,/etc/custom-allowed-path
I had to trim the server.conf file a little, cause it exceeded the character limit (only deleted stuff that was commented out)
It’s as if the elasticsearch service isn’t running:
$ sudo systemctl status elasticsearch
You can condense the server.conf file for posting with this command (found here) that eliminates comments:
cat /etc/graylog/server/server.conf         | egrep -v "^\s*(#|$)"
Don’t forget to obfuscate/remove secrets etc…
I thought that it had something to do with elasticsearch, looks like java as well:
Dec 14 19:04:18 graylog-server.cesq.com kernel: Out of memory: Killed process 2076 (java) total-vm:7617500kB, anon-rss:4136984kB, file-rss:0kB, shmem-rss:0kB, UID:992 pgtables:10536kB oom_score_adj:0
Dec 14 19:04:19 graylog-server.cesq.com systemd[1]: elasticsearch.service: Main process exited, code=killed, status=9/KILL
Dec 14 19:04:19 graylog-server.cesq.com systemd[1]: elasticsearch.service: Failed with result 'signal'.
-- Subject: Unit failed
-- Defined-By: systemd
-- Support: https://lists.freedesktop.org/mailman/listinfo/systemd-devel
-- The unit elasticsearch.service has entered the 'failed' state with result 'signal'.
Dec 14 19:04:19 graylog-server.cesq.com systemd[1]: Failed to start Elasticsearch.
-- Subject: Unit elasticsearch.service has failed
-- Unit elasticsearch.service has failed.
-- The result is failed.
I have recently edited the heap size by changing the jvm arguments to 6GB. I’ll try to revert to 1GB or 2GB and post an update. In the meantime, here’s a log from /var/log/elasticsearch/graylog.log, maybe you can make something of it, but I don’t think there’s anything of use here:
[2022-12-12T18:43:24,221][INFO ][o.e.n.Node               ] [graylog-server.cesq.com] JVM home [/usr/share/elasticsearch/jdk], using bundled JDK [true]
[2022-12-12T18:43:24,221][INFO ][o.e.n.Node               ] [graylog-server.cesq.com] JVM arguments [-Xshare:auto, -Des.networkaddress.cache.ttl=60, -Des.networkaddress.cache.negative.ttl=10, -XX:+AlwaysPreTouch, -Xss1m, -Djava.awt.headless=true, -Dfile.encoding=UTF-8, -Djna.nosys=true, -XX:-OmitStackTraceInFastThrow, -XX:+ShowCodeDetailsInExceptionMessages, -Dio.netty.noUnsafe=true, -Dio.netty.noKeySetOptimization=true, -Dio.netty.recycler.maxCapacityPerThread=0, -Dio.netty.allocator.numDirectArenas=0, -Dlog4j.shutdownHookEnabled=false, -Dlog4j2.disable.jmx=true, -Djava.locale.providers=SPI,COMPAT, -Xms1g, -Xmx1g, -XX:+UseG1GC, -XX:G1ReservePercent=25, -XX:InitiatingHeapOccupancyPercent=30, -Djava.io.tmpdir=/tmp/elasticsearch-5942910150687526801, -XX:+HeapDumpOnOutOfMemoryError, -XX:HeapDumpPath=/var/lib/elasticsearch, -XX:ErrorFile=/var/log/elasticsearch/hs_err_pid%p.log, -Xlog:gc*,gc+age=trace,safepoint:file=/var/log/elasticsearch/gc.log:utctime,pid,tags:filecount=32,filesize=64m, -XX:MaxDirectMemorySize=536870912, -Des.path.home=/usr/share/elasticsearch, -Des.path.conf=/etc/elasticsearch, -Des.distribution.flavor=oss, -Des.distribution.type=rpm, -Des.bundled_jdk=true]
[2022-12-12T18:43:24,789][INFO ][o.e.p.PluginsService     ] [graylog-server.cesq.com] loaded module [aggs-matrix-stats]
[2022-12-12T18:43:24,789][INFO ][o.e.p.PluginsService     ] [graylog-server.cesq.com] loaded module [analysis-common]
[2022-12-12T18:43:24,789][INFO ][o.e.p.PluginsService     ] [graylog-server.cesq.com] loaded module [geo]
[2022-12-12T18:43:24,790][INFO ][o.e.p.PluginsService     ] [graylog-server.cesq.com] loaded module [ingest-common]
[2022-12-12T18:43:24,790][INFO ][o.e.p.PluginsService     ] [graylog-server.cesq.com] loaded module [ingest-geoip]
[2022-12-12T18:43:24,790][INFO ][o.e.p.PluginsService     ] [graylog-server.cesq.com] loaded module [ingest-user-agent]
[2022-12-12T18:43:24,790][INFO ][o.e.p.PluginsService     ] [graylog-server.cesq.com] loaded module [kibana]
[2022-12-12T18:43:24,790][INFO ][o.e.p.PluginsService     ] [graylog-server.cesq.com] loaded module [lang-expression]
[2022-12-12T18:43:24,790][INFO ][o.e.p.PluginsService     ] [graylog-server.cesq.com] loaded module [lang-mustache]
[2022-12-12T18:43:24,791][INFO ][o.e.p.PluginsService     ] [graylog-server.cesq.com] loaded module [lang-painless]
[2022-12-12T18:43:24,791][INFO ][o.e.p.PluginsService     ] [graylog-server.cesq.com] loaded module [mapper-extras]
[2022-12-12T18:43:24,791][INFO ][o.e.p.PluginsService     ] [graylog-server.cesq.com] loaded module [parent-join]
[2022-12-12T18:43:24,791][INFO ][o.e.p.PluginsService     ] [graylog-server.cesq.com] loaded module [percolator]
[2022-12-12T18:43:24,791][INFO ][o.e.p.PluginsService     ] [graylog-server.cesq.com] loaded module [rank-eval]
[2022-12-12T18:43:24,791][INFO ][o.e.p.PluginsService     ] [graylog-server.cesq.com] loaded module [reindex]
[2022-12-12T18:43:24,791][INFO ][o.e.p.PluginsService     ] [graylog-server.cesq.com] loaded module [repository-url]
[2022-12-12T18:43:24,792][INFO ][o.e.p.PluginsService     ] [graylog-server.cesq.com] loaded module [systemd]
[2022-12-12T18:43:24,792][INFO ][o.e.p.PluginsService     ] [graylog-server.cesq.com] loaded module [transport-netty4]
[2022-12-12T18:43:24,792][INFO ][o.e.p.PluginsService     ] [graylog-server.cesq.com] no plugins loaded
[2022-12-12T18:43:24,818][INFO ][o.e.e.NodeEnvironment    ] [graylog-server.cesq.com] using [1] data paths, mounts [[/ (/dev/mapper/rl-root)]], net usable_space [6gb], net total_space [9.7gb], types [xfs]
[2022-12-12T18:43:24,818][INFO ][o.e.e.NodeEnvironment    ] [graylog-server.cesq.com] heap size [1gb], compressed ordinary object pointers [true]
[2022-12-12T18:43:24,927][INFO ][o.e.n.Node               ] [graylog-server.cesq.com] node name [graylog-server.cesq.com], node ID [jMWyIy_iS76MuqTwNW4hOA], cluster name [graylog], roles [master, remote_cluster_client, data, ingest]
[2022-12-12T18:43:26,939][INFO ][o.e.t.NettyAllocator     ] [graylog-server.cesq.com] creating NettyAllocator with the following configs: [name=unpooled, suggested_max_allocation_size=256kb, factors={es.unsafe.use_unpooled_allocator=null, g1gc_enabled=true, g1gc_region_size=1mb, heap_size=1gb}]
[2022-12-12T18:43:26,985][INFO ][o.e.d.DiscoveryModule    ] [graylog-server.cesq.com] using discovery type [zen] and seed hosts providers [settings]
[2022-12-12T18:43:27,149][WARN ][o.e.g.DanglingIndicesState] [graylog-server.cesq.com] gateway.auto_import_dangling_indices is disabled, dangling indices will not be automatically detected or imported and must be managed manually
[2022-12-12T18:43:27,251][INFO ][o.e.n.Node               ] [graylog-server.cesq.com] initialized
[2022-12-12T18:43:27,251][INFO ][o.e.n.Node               ] [graylog-server.cesq.com] starting ...
[2022-12-12T18:43:27,342][INFO ][o.e.t.TransportService   ] [graylog-server.cesq.com] publish_address {127.0.0.1:9300}, bound_addresses {[::1]:9300}, {127.0.0.1:9300}
[2022-12-12T18:43:27,493][WARN ][o.e.b.BootstrapChecks    ] [graylog-server.cesq.com] the default discovery settings are unsuitable for production use; at least one of [discovery.seed_hosts, discovery.seed_providers, cluster.initial_master_nodes] must be configured
[2022-12-12T18:43:27,494][INFO ][o.e.c.c.Coordinator      ] [graylog-server.cesq.com] cluster UUID [nI-mLLzwR924UvKii0PcIg]
[2022-12-12T18:43:27,499][INFO ][o.e.c.c.ClusterBootstrapService] [graylog-server.cesq.com] no discovery configuration found, will perform best-effort cluster bootstrapping after [3s] unless existing master is discovered
[2022-12-12T18:43:27,546][INFO ][o.e.c.s.MasterService    ] [graylog-server.cesq.com] elected-as-master ([1] nodes joined)[{graylog-server.cesq.com}{jMWyIy_iS76MuqTwNW4hOA}{DIVyLQdTTkORcVK1CAAHjw}{127.0.0.1}{127.0.0.1:9300}{dimr} elect leader, _BECOME_MASTER_TASK_, _FINISH_ELECTION_], term: 21, version: 452, delta: master node changed {previous [], current [{graylog-server.cesq.com}{jMWyIy_iS76MuqTwNW4hOA}{DIVyLQdTTkORcVK1CAAHjw}{127.0.0.1}{127.0.0.1:9300}{dimr}]}
[2022-12-12T18:43:27,585][INFO ][o.e.c.s.ClusterApplierService] [graylog-server.cesq.com] master node changed {previous [], current [{graylog-server.cesq.com}{jMWyIy_iS76MuqTwNW4hOA}{DIVyLQdTTkORcVK1CAAHjw}{127.0.0.1}{127.0.0.1:9300}{dimr}]}, term: 21, version: 452, reason: Publication{term=21, version=452}
[2022-12-12T18:43:27,619][INFO ][o.e.h.AbstractHttpServerTransport] [graylog-server.cesq.com] publish_address {127.0.0.1:9200}, bound_addresses {[::1]:9200}, {127.0.0.1:9200}
[2022-12-12T18:43:27,620][INFO ][o.e.n.Node               ] [graylog-server.cesq.com] started
[2022-12-12T18:43:27,672][INFO ][o.e.g.GatewayService     ] [graylog-server.cesq.com] recovered [22] indices into cluster_state
[2022-12-12T18:43:29,113][INFO ][o.e.c.r.a.AllocationService] [graylog-server.cesq.com] Cluster health status changed from [RED] to [GREEN] (reason: [shards started [[graylog_0][0]]]).
[2022-12-12T19:57:58,230][INFO ][o.e.n.Node               ] [graylog-server.cesq.com] stopping ...
[2022-12-12T19:57:58,360][INFO ][o.e.n.Node               ] [graylog-server.cesq.com] stopped
[2022-12-12T19:57:58,361][INFO ][o.e.n.Node               ] [graylog-server.cesq.com] closing ...
[2022-12-12T19:57:58,371][INFO ][o.e.n.Node               ] [graylog-server.cesq.com] closed
Update: Reverting the JVM options didn’t help.
What I got was out of memory from those first logs.
If ES/GL & Mongo are on the same node they might be fightingover resources.
Check /etc/elasticsearch/jvm.options
# Xms represents the initial size of total heap space
# Xmx represents the maximum size of total heap space
-Xms4g
-Xmx4g
And depending on what type of OS you have Graylog /JAVA.
https://go2docs.graylog.org/5-0/setting_up_graylog/default_file_locations.html
[root@graylog opensearch]# cat /etc/sysconfig/graylog-server
# Path to the java executable.
JAVA=/usr/bin/java
GRAYLOG_SERVER_JAVA_OPTS="-Xms3g -Xmx3g -XX:NewRatio=1
The two above examples will tell me I need at least 7 GB of RAM plus add two more for the OS.
The last set of logs it looks like Graylog service stopped, Might be something wrong with configurations.
Thank you all for helping me. Turns out I am a complete moron. I’ve assigned 6GB to Graylog when my vm maximum amount of RAM is 6GB…
Don’t drink and sysadmin kids…
Made my day @cesq :rofl:
