Elasticsearch:8.4.0 and graylog:5.1.1
while adding the xpack.security.enabled=true for elasticsearch . i am able to connect to elasticsearch with username and password, but if I am setting username , password and host for graylog its throwing me an error below.
2024-07-30 23:07:12,922 INFO : org.graylog2.plugin.system.FilePersistedNodeIdProvider - No node ID file found. Generated: 3ca7a757-8ec4-4539-9c0c-347a051f0462
2024-07-30 23:07:13,073 ERROR: org.graylog2.storage.versionprobe.VersionProbe - Unable to retrieve version from Elasticsearch node: Failed to connect to elasticsearch/192.168.176.2:9200. - Connection refused.
2024-07-30 23:07:13,074 INFO : org.graylog2.storage.versionprobe.VersionProbe - Elasticsearch is not available. Retry #1
2024-07-30 23:07:18,076 ERROR: org.graylog2.storage.versionprobe.VersionProbe - Unable to retrieve version from Elasticsearch node: Failed to connect to elasticsearch/192.168.176.2:9200. - Connection refused.
2024-07-30 23:07:18,076 INFO : org.graylog2.storage.versionprobe.VersionProbe - Elasticsearch is not available. Retry #2
2024-07-30 23:07:23,078 ERROR: org.graylog2.storage.versionprobe.VersionProbe - Unable to retrieve version from Elasticsearch node: Failed to connect to elasticsearch/192.168.176.2:9200. - Connection refused.
2024-07-30 23:07:23,078 INFO : org.graylog2.storage.versionprobe.VersionProbe - Elasticsearch is not available. Retry #3
2024-07-30 23:07:38,120 ERROR: org.graylog2.storage.versionprobe.VersionProbe - Unable to retrieve version from Elasticsearch node: Connect timed out. - Connect timed out.
2024-07-30 23:07:
  • OS Information:
  • Package Version:
Hey @balarimpy
Did you set up TLS?
I seen another issue here
@gsmith No, I have just set up the xpack.security.enable=true
2024-07-31 03:55:04,972 INFO : org.graylog2.storage.versionprobe.VersionProbe - Elasticsearch is not available. Retry #101
2024-07-31 03:55:09,977 ERROR: org.graylog2.storage.versionprobe.VersionProbe - Unable to retrieve version from Elasticsearch node elasticsearch:9200: Error response: type: security_exception - reason: missing authentication credentials for REST request [/]
2024-07-31 03:55:09,977 INFO : org.graylog2.storage.versionprobe.VersionProbe - Elasticsearch is not available. Retry #102
2024-07-31 03:55:14,984 ERROR: org.graylog2.storage.versionprobe.VersionProbe - Unable to retrieve version from Elasticsearch node elasticsearch:9200: Error response: type: security_exception - reason: missing authentication credentials for REST request [/]
2024-07-31 03:55:14,984 INFO : org.graylog2.storage.versionprobe.VersionProbe - Elasticsearch is not available. Retry #103
2024-07-31 03:55:19,987 ERROR: org.graylog2.storage.versionprobe.VersionProbe - Unable to retrieve version from Elasticsearch node elasticsearch:9200: Error response: type: security_exception - reason: missing authentication credentials for REST request [/]
2024-07-3
By chance does it work without
 xpack.security.enable=true ?
Yes, elasticsearch is working with configured username and password, but graylog shows above errors
You may want to look at the documentation here
You will notice the configuration file show this:
Or in your case with Elasticsearch it should be
xpack.security.enable=false
I think that is your issue.
