Enable payload compression for Elasticsearch requests
Hi All,
We are running Graylog 2.3.4 and Elasticsearch 5.6.0. on Centos 7 and it is running fine.
I have a couple of doubts about below two configuration setting in server.conf.
     # Default: false
Q. If the above setting is set to true does it means that all the events/logs will be stored in ES in compressed form. If yes could you share the compression ratio.??
     # Default: 20
We now at max have 15 Index Set with each index set configured to have 20 indices, with each index set to 10 GB.
Q. So shall we consider to increase optimization_jobs from default 20 to xyz. If yes from how much we should increase the jobs. Is there a formula??
Thanks in Advance.
Anant Sawant.
No, the setting enables/disables sending gzip-compressed HTTP requests to Elasticsearch.
No, this is the number of concurrent optimization jobs. In most setups, I would even reduce that number because optimizing indices in Elasticsearch is a very I/O intensive operation.
See Force Merge | Elasticsearch Reference [5.6] | Elastic for details.
