Elasticsearch Retention Period
Hi guys,
I need your advice here.
I have just realized that I’m running out of diskspace and thus have lowered the retention period down to 15 days (want to keep 2 weeks in total).
After that I have restarted both elasticsearch and graylog.
In the Elasticsearch log I see the following entry:
[2017-06-14 10:31:15,217][INFO ][cluster.routing.allocation.decider] [American Dream] rerouting shards: [high disk watermark exceeded on one or more nodes]
[2017-06-14 10:31:45,223][WARN ][cluster.routing.allocation.decider] [American Dream] high disk watermark [90%] exceeded on [6N9daCofRaqkf_8iik3GJw][American Dream][/var/opt/graylog/data/elasticsearch/graylog/nodes/0] free: 4gb[8.1%], shards will be relocated away from this node
I still see the indices in Graylog (my hope was that they would get deleted during the restart).
Would I have to manually delete the indexes myself now to free up some diskspace?
For instance: I could easily delete index graylog_0 and graylog_1 as they contain data from 2 months ago that I no longer need. Shall I delete them manually through the Graylog UI?
Hej Theresa,
what is your rotation and retention strategy you have configured?
In your Graylog Server you can always delete Indices yourself.
Hej Jan,
what I don’t understand is that Elasticsearch is configured to delete old indices that it no longer needs to free up some diskspace.
My current configuration is:
Rotation strategy: Index Time
Rotation period: P1D
Retention strategy: Delete Index
Max number of indices: 8
However, my file system where the elasticsearch data is stored was 100% full this morning…is there something that I forgot to configure yet?
I’ve made my changes through the web-interface.
Hej @micsnare
I do not know why this happens - or better not happens. Did you try to delete the indices manually
Jan
Hej @jan
yep, I deleted them manually through the webui and managed to recover the elasticsearch cluster (it was in a red state previously due to the full filesystem). I will monitor the situation over the weekend :wink:
theresa.
