I’m having this problem, but I don’t know how to solve it
I would be very appriciated for answer and solutions ![]()
your Elasticsearch server has run out of disk space - you need to either grow your disks, move your data to a larger disk or reduce your index retention. You can search the forum for this, it has happened to many others. Once you have solved the disk problem, you will likely need to reset Elasticsearch from read only to read/write.
