Graylog and elasticsearch issue
i have latest graylog on ubuntu (fresh installation)
after login i have error:
Elasticsearch nodes disk usage above low watermark (triggered an hour ago)
There are Elasticsearch nodes in the cluster running out of disk space, their disk usage is above the low watermark. For this reason Elasticsearch will not allocate new shards to the affected nodes. The affected nodes are: [127.0.0.1] Check Cluster-level shard allocation and routing settings | Reference for more details.
i don’t have cluster and 5 gig back .
Hello
It stating you running out of room on your Graylog server
Check your GL server.
root # df -h
Or this could be the way this environment is configured. Hard to tell with the lack of information.
