Down cluster with 3 node
Hello. I have a cluster of 3 nodes with elastic (2 node with graylog, and 1 single node with elastic), when one falls, the entire cluster fails (and becomes red). How can I fix this so that when one node fails, the rest work? My elastic settings:
cluster.name: graylog
node.name: es-node-01
#node.attr.rack: r1
path.data:
   - /var/lib/elasticsearch/data1
   - /var/lib/elasticsearch/data2
path.logs: /var/log/elasticsearch
#bootstrap.memory_lock: true
network.host: 10.101.15.231
http.port: 9200
discovery.seed_hosts: ["10.101.15.231", "10.101.15.232", "10.101.15.233"]
discovery.zen.fd.ping_timeout: 10s
discovery.zen.minimum_master_nodes: 2
cluster.initial_master_nodes:
  - es-node-01
  - es-node-02
  - es-node-03
#gateway.recover_after_nodes: 3
#action.destructive_requires_name: true
node.roles: [ data, master ]
cluster.routing.allocation.disk.watermark.low: "20G"
cluster.routing.allocation.disk.watermark.high: "10G"
cluster.routing.allocation.disk.watermark.flood_stage: "5G"
path.repo:
   - /var/lib/elasticsearch/data1/backup
By chance is this related to this post.
As for you question.
You might want to read this documentation on Multi-node Setup.
https://docs.graylog.org/en/4.1/pages/configuration/multinode_setup.html#configure-multinode
Also this documentation is very helpful.
Hope that helps
This is my post, but they are not related in any way, these are two different tasks
I read the documentation, but for some reason nothing works. I made the elastic cluster setup as shown in the official documentation (if I understood it correctly):
#node.attr.rack: r1
path.data:
http.port: 9200
  - es-node-01
  - es-node-02
  - es-node-03
path.repo:
the configuration is the same on all nodes
Is solved. I just needed add replics in index.
Nice, and thanks for posting how you fixed it. This will help other down the road that may have the same problem/s.
