Graylog 3.0.2 cluster fail
i have 2 node
node 1:10.10.200.25
node2:10.10.200.26
i want setup cluster, but it show this message
please told me how to fix it
Node 1
is_master = true
password_secret = IJgfiEmgncIBXTcxI1W8b37eGTUY9yMPbqIRkVwS8NMoRE8A8SP4L8aM6D8nOf3BI73y6oUzjkJCeEwe6n6H0VNAkBNVDF2s
root_username = admin
root_password_sha2 = 231ecc7d178da5f22983bc579599396d6c139a457987ae1ee0026d88432d6a72
root_timezone = Asia/Manila
elasticsearch_hosts = http://10.10.200.27:9200,http://10.10.200.28:9200
rotation_strategy = count
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 0
allow_highlighting = false
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
stale_master_timeout = 2000
Node 2
is_master = false
ring_size = 65536
you might want to read: http://docs.graylog.org/en/3.0/pages/configuration/multinode_setup.html
that should help you - if you have questions, post specific questions. If you have configurations, do not post images, use content formatting in this community to make your config readable.
the graylog document cant help me
i already upload tow node config
could u help me check these config?
i dont know which setting is fail, that let graylog cant run cluster
I can’t read your configuration proper. Sorry you need to edit your previous postings to make them more readable.
already edit the post
please help to solve it
thanks
every Graylog uses localhost as MongoDB - if you did not replicate that, you have two single Graylog using the same Elasticsearch cluster.
thanks your help
after setting mongo replica set
it work now
