DMARC XML parsing with logstash and Graylog
Hi Guys,
Has anyone done parsing of XML files into Graylog? I am trying that but logs are not being ingested.
can someone please help me about parsing XML files into graylog? I am trying to parse DMARC XML files into graylog.
TIA
Blason R
As @jochen already pointed out in Extracting XML fields parsing of XML should happen before putting the logs into graylog.
Yes that is obvious and I am trying with logstash with below config or using the @wwalker config.
somehow the logs are not being ingested then.
Here is the config file I am referring to
Don’t try to write directly to elasticsearch, but use logstash GELF output plugin and a GELF input in Graylog.
This is what is done exactly!!! But dang its not going through. May be I try to debug now.
