Dashboards for Centralized HTTP Monitoring don't show data after change or move some dashboard
hello
I made a new installation first of graylog for 5.0 and now i upgrade to 5.1.7.
I installed the following content pack:
everything is ok, the graphs appear but as soon as I delete one of them or try to change the graphs to another page the data disappears and the graphs don’t update.
Can you give any help as to what is happening?
Thank you
If you edit any of those widgets in the second image, does it load in the edit page, or if you copy the search query from that widget does it return data in the normal search page?
yes it appears but in the main page don’t
