Dashboard Ordering of Tabs
After upgrading Graylog Open from 5.07 to 5.1, my dashboard tabs have been re-ordered. When I order them back the way I want, the order does not change.
  • OS Information: Ubuntu 22.04
  • Package Version: 5.1, using ElasticSearch 7.10.2
    I can include if needed.
I have tried to re-order the tabs, but the changes are not saved.
Is anyone else experiencing this, or just me? Happy to note a bug if that is what the problem is.
Thanks for the report. I ran into this myself and opened an issue for it:
A fix will likely be issued with the next “bugfix” release for Graylog 5.1. I can’t make any promises or commitments, but the tentative release is on 7th of June.
@drewmiranda-gl this appears to be fixed in 5.1.1, which was released very recently. Thanks again for adding the issue!!
