Custom Grok pattern
(Alain) #1
Hi all,
I’m looking for making a dashboard with datas coming from PLCs.
Theese datas look like
[{"tag":"DO_SIMU[199].1","value":"False","time":"2018-09-05T14:35:09.1189226+02:00"}]
[{"tag":"DO_SIMU[199].2","value":"True","time":"2018-10-05T14:35:09.1189226+02:00"}]
[{"tag":"asefsfdfsd","value":"135","time":"2018-09-05T14:35:09.1189226+02:00"}]
[{"tag":"tit.1","value":"152.551","time":"2018-09-05T14:35:09.1189226+02:00"}]
[{"tag":"DO_SIMU[1].2551","value":"False","time":"6454-09-05T14:35:09.1189226+02:00"}]
[{"tag":"kfmdsfsmdlf.i1","value":"maman","time":"2018-09-05T14:35:09.1189226+15:251"}]
I have to create for each line a variable called with the value of tag (DO_SIMU[199].1 or kfmdsfsmdlf.i1 for example) and to put in this value the value of value
This last step seems to be easy with json
So I’m looking for create a grok pattern that just return me something like
{"DO_SIMU[199].1":"False"}
excluding all the rest.
If somebody have an idea, I thank him in advance.
Create a field which name is the value from another on
(Alain) #2
I progressed since.
With a 1st pattern ( ^[[^]]) I created an intermediate field who’s the same without the square brakets.
On this intermediate field, I applied (\A{%{QS}:%{QS:xxx_tag},%{QS}:%{QS:xxx_value},%{QS}:%{QS}}) with only the named tags.
So I now have two fields : xxx_tag and xxx_value
(system) #3
