Hello, fresh docker install, no errors in my mongodb/opensearch/graylog containers, but on the web interface, i got this one :
Even though i can access it :
graylog@server:~$ curl http://opensearch:9200
"name" : "3942973263d4",
"cluster_name" : "docker-cluster",
"cluster_uuid" : "osMut6a-QMymQXTDNzStnQ",
"version" : {
"distribution" : "opensearch",
"number" : "2.4.0",
"build_type" : "tar",
"build_hash" : "744ca260b892d119be8164f48d92b8810bd7801c",
"build_date" : "2022-11-15T04:42:29.671309257Z",
"build_snapshot" : false,
"lucene_version" : "9.4.1",
"minimum_wire_compatibility_version" : "7.10.0",
"minimum_index_compatibility_version" : "7.0.0"
"tagline" : "The OpenSearch Project: https://opensearch.org/"
OS Information: Debian 11
Package Version:
- mondobg:5.0
- opensearch:2.4.0
- graylog:6.0.7
- Service logs, configurations, and environment variables:
Docker-compose.yml :
version: "3"
services:
mongodb:
image: "mongo:5.0"
volumes:
- "/mnt/data01/graylog/mongodb:/data/db"
restart: "on-failure"
opensearch:
image: "opensearchproject/opensearch:2.4.0"
environment:
- "OPENSEARCH_JAVA_OPTS=-Xms1g -Xmx1g"
- "bootstrap.memory_lock=true"
- "discovery.type=single-node"
- "action.auto_create_index=false"
- "plugins.security.ssl.http.enabled=false"
- "plugins.security.disabled=true"
volumes:
- "/mnt/data01/graylog/opensearch:/usr/share/opensearch/data"
graylog:
hostname: "server"
image: "graylog/graylog:6.0.7"
entrypoint: "/usr/bin/tini -- wait-for-it opensearch:9200 -- /docker-entrypoint.sh"
environment:
GRAYLOG_NODE_ID_FILE: "/usr/share/graylog/data/config/node-id"
GRAYLOG_PASSWORD_SECRET: "yyy"
GRAYLOG_ROOT_PASSWORD_SHA2: "xxxx"
GRAYLOG_HTTP_BIND_ADDRESS: "0.0.0.0:9000"
GRAYLOG_HTTP_EXTERNAL_URI: "http://localhost:9000/"
GRAYLOG_ELASTICSEARCH_HOSTS: "http://opensearch:9200"
GRAYLOG_MONGODB_URI: "mongodb://mongodb:27017/graylog"
ports:
- "5044:5044/tcp" # Beats
- "5140:5140/udp" # Syslog
- "5140:5140/tcp" # Syslog
- "5141:5141/udp" # Syslog
- "5555:5555/tcp" # RAW TCP
- "5555:5555/udp" # RAW TCP
- "9000:9000/tcp" # Server API
- "12201:12201/tcp" # GELF TCP
- "12201:12201/udp" # GELF UDP
- "13301:13301/tcp" # Forwarder data
- "13302:13302/tcp" # Forwarder config
volumes:
- "/mnt/data01/graylog/data:/usr/share/graylog/data/data"
- "/mnt/data01/graylog/journal:/usr/share/graylog/data/journal"
I’ve got no errors in my logs, nothing about some rights in my /mnt/data01/graylog/xxx.
