Could not load quick values (500)
hello, I am interested in graylog and want to know if graylog can meet my needs. unfortunately I always get this error message (screeshot in link below)when trying to create Quick Value, Generate Chart and more on the message fields.
I tried it on a nginx requests stream that came with a virtual appliance.
I’ve been looking for a solution on google but unfortunately have not got it.
thank you for any help.
Screenshot (gdrive)
maybe this can help you: Error with "message" and "source" fields
Hope this helps :thinking:
Any errors in the log files of Graylog or Elasticsearch?
hi zionio, thanks for the suggestion.
as the link says, i have enabled message “UI analysis disabled for fields” as well. but the error still appears.
hi jtkarvo,
this the error log from graylog
cat /var/log/graylog/server/current | grep ERROR
2018-01-11_15:22:16.44599 ERROR [NettyTransport] Error in Input [Syslog UDP/5a578127b5e33105caf1b9aa] (channel [id: 0x24591f7c, /0:0:0:0:0:0:0:0:514])
2018-01-11_15:22:18.66928 ERROR [LookupDataAdapter] Couldn’t start data adapter spamhaus-drop/5a578129b5e33105caf1b9ed/@46debff5
2018-01-11_15:22:18.67725 ERROR [LookupDataAdapter] Couldn’t start data adapter abuse-ch-ransomware-domains/5a578129b5e33105caf1b9e4/@6927067a
2018-01-11_15:22:38.51322 ERROR [InputLauncher] The [org.graylog2.inputs.syslog.udp.SyslogUDPInput] input with ID <5a578127b5e33105caf1b9aa> misfired. Reason: Address already in use.
2018-01-11_15:22:38.58216 ERROR [graylog-eventbus] Exception thrown by subscriber method inputStateChanged(org.graylog2.plugin.events.inputs.IOStateChangedEvent) on subscriber org.graylog2.inputs.InputStateListener@7b5c9412 when dispatching event: IOStateChangedEvent{oldState=STARTING, newState=FAILED, changedState=InputState{stoppable=SyslogUDPInput{title=appliance-syslog-udp, type=org.graylog2.inputs.syslog.udp.SyslogUDPInput, nodeId=a25c0ba2-ca9c-4f18-97b7-2b4214375dfe}, state=FAILED, startedAt=2018-01-11T15:22:38.425Z, detailedMessage=‘null’}}
and this one
cat /var/log/graylog/server/current | grep WARN
2018-01-11_15:22:06.78644 WARN [NodeChecker] Removing host http ://192.168.2.140:9200
2018-01-11_15:22:11.65070 WARN [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2018-01-11_15:22:11.71318 WARN [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2018-01-11_15:22:12.80067 WARN [DeadEventLoggingListener] Received unhandled event of type <org.graylog2.plugin.lifecycles.Lifecycle> from event bus <AsyncEventBus{graylog-eventbus}>
2018-01-11_15:22:16.38702 WARN [NettyTransport] receiveBufferSize (SO_RCVBUF) for input GELFUDPInput{title=appliance-gelf-udp, type=org.graylog2.inputs.gelf.udp.GELFUDPInput, nodeId=null} should be 1048576 but is 212992.
2018-01-11_15:22:16.67320 WARN [NettyTransport] receiveBufferSize (SO_RCVBUF) for input SyslogUDPInput{title=appliance-syslog-udp, type=org.graylog2.inputs.syslog.udp.SyslogUDPInput, nodeId=a25c0ba2-ca9c-4f18-97b7-2b4214375dfe} should be 262144 but is 212992.
2018-01-11_15:22:17.36759 WARN [NettyTransport] receiveBufferSize (SO_RCVBUF) for input GELFUDPInput{title=appliance-gelf-udp, type=org.graylog2.inputs.gelf.udp.GELFUDPInput, nodeId=a25c0ba2-ca9c-4f18-97b7-2b4214375dfe} should be 1048576 but is 212992.
2018-01-11_15:22:18.62365 WARN [OTXDataAdapter] OTX API key is missing. Make sure to add the key to allow higher request limits.
2018-01-11_15:22:18.67458 WARN [OTXDataAdapter] OTX API key is missing. Make sure to add the key to allow higher request limits.
2018-01-11_15:25:15.07560 WARN [NettyTransport] receiveBufferSize (SO_RCVBUF) for input SyslogUDPInput{title=appliance-syslog-udp, type=org.graylog2.inputs.syslog.udp.SyslogUDPInput, nodeId=a25c0ba2-ca9c-4f18-97b7-2b4214375dfe} should be 262144 but is 212992.
but i dont see any warning or error in elasticsearch log.
UPDATE :
I got this error when opening a link containing errors directly in the browser
Unable to perform terms query\n\nFielddata is disabled on text fields by default. Set fielddata=true on [message] in order to load fielddata in memory by uninverting the inverted index. Note that this can however use significant memory. Alternatively use a keyword field instead.
Hello, all. I solved this problem by using an extractor. whether this is the right step or not but with this i can adding message to dashboard.
could you please inform me how to do this?
also isn’t there any hope to activate the quick values for messages?
Just check - for example “System > Configurations” in your Graylog setup …
thanks to guide me what to do in the “System > Configurations” section
i found the below error message from browser which may clarify the problem facnig me:
{“message”:“Unable to perform terms query\n\nFielddata is disabled on text fields by default. Set fielddata=true on [source] in order to load fielddata in memory by uninverting the inverted index. Note that this can however use significant memory. Alternatively use a keyword field instead.”,“details”:[“Fielddata is disabled on text fields by default. Set fielddata=true on [source] in order to load fielddata in memory by uninverting the inverted index. Note that this can however use significant memory. Alternatively use a keyword field instead.”]}
how can i enable the metioned term as this may solve the issue?
you should read the elasticsearch documentation on that:
https://www.elastic.co/guide/en/elasticsearch/reference/5.0/fielddata.html#_fielddata_is_disabled_on_literal_text_literal_fields_by_default
i did bu it’s really to hard to get the needed steps clearly as i’m not an expert also it seems there’s no clear text file to edit in the server; so i’ve to change in a DB or somthing like that!
could you please summaries to me the actual steps in a simple form?
you should not change the details if you did not get it yourself.
