Could not get journal information when clicking on system/nodes
When we click on system/nodes, we can’t get info about the disk journal -> it keeps on loading with message “loading journal metrics”.
I get an error “could not get journal information” see below. Any tips on troubleshooting, solving this one?
System
Hostname:
xxxxx
Node ID:
db66378a-1215-4465-9e9f-77f4ceae15b6
Version:
3.2.2+2f9a628, codename Ethereal Elk
JVM:
PID 643, Private Build 1.8.0_242 on Linux 4.15.0-88-generic
Time:
2020-03-03 10:11:49 +01:00
REST API
Last seen:
in a few seconds
Installed plugins 4 plugins installed
Name Version Author Description
AWS plugins 3.2.2 Graylog, Inc. Collection of plugins to read data from or interact with the Amazon Web Services (AWS).
Collector 3.2.2 Graylog, Inc. Collectors plugin
Integrations 3.2.2 Graylog, Inc. hello@graylog.com A collection of plugins that integrate external systems with Graylog. [
Threat Intelligence Plugin 3.2.2 Graylog, Inc. Threat intelligence database lookup functions for the Graylog Pipeline Processor
Available input types 2 inputs running on this node
Name Type Documentation
AWS CloudTrail Input org.graylog.aws.inputs.cloudtrail.CloudTrailInput
AWS Flow Logs (deprecated) org.graylog.aws.inputs.flowlogs.FlowLogsInput
AWS Kinesis/CloudWatch org.graylog.integrations.aws.inputs.AWSInput
AWS Logs (deprecated) org.graylog.aws.inputs.cloudwatch.CloudWatchLogsInput
Beats org.graylog.plugins.beats.Beats2Input
Beats (deprecated) org.graylog.plugins.beats.BeatsInput
CEF AMQP Input org.graylog.plugins.cef.input.CEFAmqpInput
CEF Kafka Input org.graylog.plugins.cef.input.CEFKafkaInput
CEF TCP Input org.graylog.plugins.cef.input.CEFTCPInput
CEF UDP Input org.graylog.plugins.cef.input.CEFUDPInput
GELF AMQP org.graylog2.inputs.gelf.amqp.GELFAMQPInput
GELF HTTP org.graylog2.inputs.gelf.http.GELFHttpInput
GELF Kafka org.graylog2.inputs.gelf.kafka.GELFKafkaInput
GELF TCP org.graylog2.inputs.gelf.tcp.GELFTCPInput
GELF UDP org.graylog2.inputs.gelf.udp.GELFUDPInput
IPFIX UDP org.graylog.integrations.ipfix.inputs.IpfixUdpInput [Documentation ]
JSON path from HTTP API org.graylog2.inputs.misc.jsonpath.JsonPathInput [Documentation ]
NetFlow UDP org.graylog.plugins.netflow.inputs.NetFlowUdpInput [Documentation ]
Palo Alto Networks Input (TCP) org.graylog.integrations.inputs.paloalto.PaloAltoTCPInput
Random HTTP message generator org.graylog2.inputs.random.FakeHttpMessageInput
Raw/Plaintext AMQP org.graylog2.inputs.raw.amqp.RawAMQPInput
Raw/Plaintext Kafka org.graylog2.inputs.raw.kafka.RawKafkaInput
Raw/Plaintext TCP org.graylog2.inputs.raw.tcp.RawTCPInput
Raw/Plaintext UDP org.graylog2.inputs.raw.udp.RawUDPInput
Syslog AMQP org.graylog2.inputs.syslog.amqp.SyslogAMQPInput
Syslog Kafka org.graylog2.inputs.syslog.kafka.SyslogKafkaInput
Syslog TCP org.graylog2.inputs.syslog.tcp.SyslogTCPInput
Syslog UDP org.graylog2.inputs.syslog.udp.SyslogUDPInput
Graylog 3.2.2
Getting journal information on node db66378a-1215-4465-9e9f-77f4ceae15b6 failed: Error: cannot GET http://x.x.x.x:9000/api/cluster/db66378a-1215-4465-9e9f-77f4ceae15b6/journal (400)
He @tmichiels
this is a known Issue that will be fixed in 3.2.3
OK thanks, any idea when 3.2.3 will be available?
