Graylog want start
Please I can’t start graylog and I have this warn :
2018-07-30T10:08:16.081+02:00 WARN  [NettyTransport] receiveBufferSize (SO_RCVBUF) for input BeatsInput{title=frghcslnetv04, type=org.graylog.plugins.beats.BeatsInput, nodeId=82702595-8116-4676-a17d-ea606560cb75} should be 1048576 but is 212992.
2018-07-30T10:08:16.088+02:00 INFO  [InputStateListener] Input [Beats/5b27800b526a9b0c14ef077d] is now RUNNING
2018-07-30T10:08:16.101+02:00 INFO  [KafkaJournal] Read offset 284769557 before start of log at 290327808, starting to read from the beginning of the journal.
2018-07-30T10:08:23.229+02:00 INFO  [KafkaJournal] Read offset 284769557 before start of log at 290327808, starting to read from the beginning of the journal.
2018-07-30T10:10:00.628+02:00 ERROR [Cluster] Couldn't read cluster health for indices [graylog_*] (Could not connect to http://127.0.0.1:9200)
2018-07-30T10:10:00.628+02:00 INFO  [IndexerClusterCheckerThread] Indexer not fully initialized yet. Skipping periodic cluster check.
2018-07-30T10:11:30.584+02:00 WARN  [KafkaJournal] Journal utilization (108.0%) has gone over 95%.
2018-07-30T10:11:30.586+02:00 INFO  [KafkaJournal] Journal usage is 108.00% (threshold 100%), changing load balancer status from ALIVE to THROTTLED
2018-07-30T10:12:30.591+02:00 WARN  [KafkaJournal] Journal utilization (136.0%) has gone over 95%.
2018-07-30T10:13:30.578+02:00 WARN  [KafkaJournal] Journal utilization (137.0%) has gone over 95%.
2018-07-30T10:14:30.583+02:00 WARN  [KafkaJournal] Journal utilization (136.0%) has gone over 95%.
2018-07-30T10:15:30.584+02:00 WARN  [KafkaJournal] Journal utilization (135.0%) has gone over 95%.
How can I solve this ?
hi salma
can you show us the graylog status??
and see
[root@frghcslnetv11 ~]# systemctl status graylog-server.service
   Loaded: loaded (/usr/lib/systemd/system/graylog-server.service; enabled; vendor preset: disabled)
   Active: active (running) since Mon 2018-07-30 11:53:20 CEST; 2h 10min ago
     Docs: http://docs.graylog.org/
 Main PID: 23215 (graylog-server)
    Tasks: 122
   CGroup: /system.slice/graylog-server.service
           ├─23215 /bin/sh /usr/share/graylog-server/bin/graylog-server
           └─23216 /usr/bin/java -Xms4g -Xmx4g -XX:NewRatio=1 -server -XX:+ResizeTLAB -XX:+UseConcMarkSweepGC -XX:+CMSConcurrentMTEnabled -XX:+CMSClassUnloadingEnabled -XX:+U...
Jul 30 11:53:20 frghcslnetv11 systemd[1]: Started Graylog server.
Jul 30 11:53:20 frghcslnetv11 systemd[1]: Starting Graylog server...
On Elasticsearch logs, I have this warn :
[2018-07-30T10:29:18,258][WARN ][o.e.i.e.Engine           ] [9hSWSDU] [graylog_6][3] failed to rollback writer on close
java.nio.file.NoSuchFileException: /data/elasticsearch/nodes/0/indices/S7Pj25k1Rj6bark5lKr-OQ/3/index
        at sun.nio.fs.UnixException.translateToIOException(UnixException.java:86) ~[?:?]
        at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:102) ~[?:?]
        at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:107) ~[?:?]
        at sun.nio.fs.UnixFileSystemProvider.newDirectoryStream(UnixFileSystemProvider.java:427) ~[?:?]
        at java.nio.file.Files.newDirectoryStream(Files.java:457) ~[?:1.8.0_171]
        at org.apache.lucene.store.FSDirectory.listAll(FSDirectory.java:215) ~[lucene-core-6.6.1.jar:6.6.1 9aa465a89b64ff2dabe7b4d50c472de32c298683 - varunthacker - 2017-08-29 21:54:39]
        at org.apache.lucene.store.FSDirectory.listAll(FSDirectory.java:234) ~[lucene-core-6.6.1.jar:6.6.1 9aa465a89b64ff2dabe7b4d50c472de32c298683 - varunthacker - 2017-08-29 21:54:39]
        at org.apache.lucene.store.FilterDirectory.listAll(FilterDirectory.java:57) ~[lucene-core-6.6.1.jar:6.6.1 9aa465a89b64ff2dabe7b4d50c472de32c298683 - varunthacker - 2017-08-29 21:54:39]
        at org.apache.lucene.index.IndexFileDeleter.refresh(IndexFileDeleter.java:429) ~[lucene-core-6.6.1.jar:6.6.1 9aa465a89b64ff2dabe7b4d50c472de32c298683 - varunthacker - 2017-08-29 21:54:39]
        at org.apache.lucene.index.IndexWriter.rollbackInternalNoCommit(IndexWriter.java:2249) ~[lucene-core-6.6.1.jar:6.6.1 9aa465a89b64ff2dabe7b4d50c472de32c298683 - varunthacker - 2017-08-29 21:54:39]
        at org.apache.lucene.index.IndexWriter.rollbackInternal(IndexWriter.java:2193) ~[lucene-core-6.6.1.jar:6.6.1 9aa465a89b64ff2dabe7b4d50c472de32c298683 - varunthacker - 2017-08-29 21:54:39]
        at org.apache.lucene.index.IndexWriter.rollback(IndexWriter.java:2186) ~[lucene-core-6.6.1.jar:6.6.1 9aa465a89b64ff2dabe7b4d50c472de32c298683 - varunthacker - 2017-08-29 21:54:39]
        at org.elasticsearch.index.engine.InternalEngine.closeNoLock(InternalEngine.java:1342) ~[elasticsearch-5.6.10.jar:5.6.10]
        at org.elasticsearch.index.engine.Engine.close(Engine.java:1252) ~[elasticsearch-5.6.10.jar:5.6.10]
        at org.elasticsearch.index.engine.Engine.flushAndClose(Engine.java:1239) ~[elasticsearch-5.6.10.jar:5.6.10]
        at org.elasticsearch.index.shard.IndexShard.close(IndexShard.java:920) ~[elasticsearch-5.6.10.jar:5.6.10]
        at org.elasticsearch.index.IndexService.closeShard(IndexService.java:407) ~[elasticsearch-5.6.10.jar:5.6.10]
        at org.elasticsearch.index.IndexService.removeShard(IndexService.java:390) ~[elasticsearch-5.6.10.jar:5.6.10]
        at org.elasticsearch.index.IndexService.close(IndexService.java:246) ~[elasticsearch-5.6.10.jar:5.6.10]
        at org.elasticsearch.indices.IndicesService.removeIndex(IndicesService.java:539) ~[elasticsearch-5.6.10.jar:5.6.10]
        at org.elasticsearch.indices.IndicesService.lambda$doStop$2(IndicesService.java:240) ~[elasticsearch-5.6.10.jar:5.6.10]
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_171]
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_171]
        at java.lang.Thread.run(Thread.java:748) [?:1.8.0_171]
did u check ur the capacity of ur disque ??
I add more CPU and RAM and now I have those errors :
[root@frghcslnetv11 graylog-server]# tail -30 server.log
2018-07-31T13:47:49.502+02:00 ERROR [NettyTransport] Error in Input [Beats/5b27800b526a9b0c14ef077d] (channel [id: 0x2e830dd8, /172.16.250.20:35448 => /172.16.250.19:5044])
java.lang.OutOfMemoryError: Java heap space
2018-07-31T13:43:40.321+02:00 ERROR [NettyTransport] Error in Input [Beats/5b27800b526a9b0c14ef077d] (channel [id: 0x3c3c31d6, /172.16.250.20:35148 :> /172.16.250.19:5044])
2018-07-31T13:47:49.502+02:00 ERROR [NettyTransport] Error in Input [Beats/5b27800b526a9b0c14ef077d] (channel [id: 0x23cfa1c7, /172.16.250.20:35597 :> /172.16.250.19:5044])
2018-07-31T13:48:08.175+02:00 ERROR [NettyTransport] Error in Input [Beats/5b27800b526a9b0c14ef077d] (channel [id: 0x2e830dd8, /172.16.250.20:35448 :> /172.16.250.19:5044])
2018-07-31T13:47:49.502+02:00 ERROR [NettyTransport] Error in Input [Beats/5b27800b526a9b0c14ef077d] (channel [id: 0xebd88267, /172.16.250.20:39069 :> /172.16.250.19:5044])
2018-07-31T13:44:31.316+02:00 ERROR [NettyTransport] Error in Input [Beats/5b27800b526a9b0c14ef077d] (channel [id: 0xf6ab20c3, /172.16.250.20:36621 :> /172.16.250.19:5044])
2018-07-31T13:50:42.483+02:00 ERROR [NettyTransport] Error in Input [Beats/5b27800b526a9b0c14ef077d] (channel [id: 0x3ef16c26, /172.16.250.20:38603 => /172.16.250.19:5044])
2018-07-31T13:51:09.470+02:00 ERROR [NettyTransport] Error in Input [Beats/5b27800b526a9b0c14ef077d] (channel [id: 0xae75fdd2, /172.16.250.20:41738 => /172.16.250.19:5044])
2018-07-31T13:52:49.141+02:00 ERROR [NettyTransport] Error in Input [Beats/5b27800b526a9b0c14ef077d] (channel [id: 0x9bae2490, /172.16.250.20:34734 => /172.16.250.19:5044])
2018-07-31T13:43:58.206+02:00 ERROR [NettyTransport] Error in Input [Beats/5b27800b526a9b0c14ef077d] (channel [id: 0x73c99663, /172.16.250.20:37480 :> /172.16.250.19:5044])
2018-07-31T13:49:51.012+02:00 ERROR [NettyTransport] Error in Input [Beats/5b27800b526a9b0c14ef077d] (channel [id: 0x45b634d5, /172.16.250.20:38234 :> /172.16.250.19:5044])
2018-07-31T13:52:08.194+02:00 ERROR [NettyTransport] Error in Input [Beats/5b27800b526a9b0c14ef077d] (channel [id: 0xcfb1f15a, /172.16.250.20:39186 :> /172.16.250.19:5044])
2018-07-31T13:56:27.694+02:00 ERROR [NettyTransport] Error in Input [Beats/5b27800b526a9b0c14ef077d] (channel [id: 0x4367245d, /172.16.250.20:34741 => /172.16.250.19:5044])
2018-07-31T13:54:10.592+02:00 ERROR [NettyTransport] Error in Input [Beats/5b27800b526a9b0c14ef077d] (channel [id: 0x12020977, /172.16.250.20:39104 => /172.16.250.19:5044])
2018-07-31T13:53:34.624+02:00 ERROR [NettyTransport] Error in Input [Beats/5b27800b526a9b0c14ef077d] (channel [id: 0x9bae2490, /172.16.250.20:34734 :> /172.16.250.19:5044])
ur virtual machine haven’t enough space to run graylog i think check ur disk by using the command line df-v if u see that ur disck is totally check the directory /var/log (df -h ) and delete the logs and i think it wil works
[root@frghcslnetv11 server]# df -h
Filesystem                 Size  Used Avail Use% Mounted on
/dev/mapper/vgroot-root     22G  9.9G   12G  47% /
devtmpfs                   3.8G     0  3.8G   0% /dev
tmpfs                      3.9G     0  3.9G   0% /dev/shm
tmpfs                      3.9G   21M  3.8G   1% /run
tmpfs                      3.9G     0  3.9G   0% /sys/fs/cgroup
/dev/sda1                 1014M  261M  754M  26% /boot
/dev/mapper/vgdata-lvdata  196G  4.7G  183G   3% /data
tmpfs                      781M     0  781M   0% /run/user/6012
tmpfs                      781M     0  781M   0% /run/user/0
And I don’t know why there is data on the buffer and nothing goeas out on elasticsearch ?
did you check the health of your cluster if it is green or not ??
Yes the cluster is green
you can check this link
hada lah
