Compiling modified graylog project
Hi all,
I have modified the master branch code for graylog and I want to create a docker image out of it.
i have used mvn -Dmaven.javadoc.skip=true -DskipTests package to create the jar files and tried to copy the stracture of these files as best as I can from the structure of graylog 5.0 package.
i have created the image using this repo:
slightly modified it so it wouldn’t take the package from the graylog site but us my own package.
once the image starts, after opensearch boots up I am getting this errer:
Exception in thread “main”
java.lang.NoClassDefFoundError: com/github/rvesse/airline/Cli
at org.graylog2.bootstrap.Main.main(Main.java:34)
Caused by: java.lang.ClassNotFoundException: com.github.rvesse.airline.Cli
at java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(Unknown Source)
at java.base/jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(Unknown Source)
at java.base/java.lang.ClassLoader.loadClass(Unknown Source)
... 1 more
which makes me think there was something wrong with the package command/ the way I took the jar files?
it works great when building the develop image or running locally from the IDE
