Upgrade from 5.0.8 to 6.0.3
While upgrading the graylog image from 5.0.8 to 6.0.3, getting below error.
at org.graylog2.bootstrap.CmdLineTool.run(CmdLineTool.java:267) [graylog.jar:?]
at org.graylog2.bootstrap.Main.main(Main.java:55) [graylog.jar:?]
Caused by: java.lang.ClassNotFoundException: javax.inject.Provider
at java.base/java.net.URLClassLoader.findClass(Unknown Source) ~[?:?]
at java.base/java.lang.ClassLoader.loadClass(Unknown Source) ~[?:?]
at java.base/java.net.FactoryURLClassLoader.loadClass(Unknown Source) ~[?:?]
... 26 more
Exception in thread "main" java.lang.NoClassDefFoundError: javax/inject/Provider
we are using docker image from docker hub graylog/graylog:6.0.3
  • OS Information:
  • its docker
  • Package Version:
  • 6.0.3
2024-06-25 12:36:12,450 INFO [Version] - HV000001: Hibernate Validator null - {}
2024-06-25 12:36:14,887 ERROR [CmdLineTool] - Startup error: - {}
at java.base/java.lang.ClassLoader.defineClass1(Native Method) ~[?:?]
at java.base/java.lang.ClassLoader.defineClass(Unknown Source) ~[?:?]
at java.base/java.security.SecureClassLoader.defineClass(Unknown Source) ~[?:?]
at java.base/java.net.URLClassLoader.defineClass(Unknown Source) ~[?:?]
at java.base/java.net.URLClassLoader$1.run(Unknown Source) ~[?:?]
at java.base/java.security.AccessController.doPrivileged(Unknown Source) ~[?:?]
at org.graylog.plugins.metrics.prometheus.MetricsPrometheusReporterModule.configure(MetricsPrometheusReporterModule.java:43) ~[?:?]
at com.google.inject.AbstractModule.configure(AbstractModule.java:64) ~[graylog.jar:?]
at com.google.inject.spi.Elements$RecordingBinder.install(Elements.java:426) ~[graylog.jar:?]
at org.graylog2.shared.bindings.PluginBindings.configure(PluginBindings.java:57) ~[graylog.jar:?]
at com.google.inject.spi.Elements.getElements(Elements.java:113) ~[graylog.jar:?]
at com.google.inject.internal.InjectorShell$Builder.build(InjectorShell.java:160) ~[graylog.jar:?]
at com.google.inject.internal.InternalInjectorCreator.build(InternalInjectorCreator.java:107) ~[graylog.jar:?]
at com.google.inject.Guice.createInjector(Guice.java:87) ~[graylog.jar:?]
at org.graylog2.shared.bindings.GuiceInjectorHolder.createInjector(GuiceInjectorHolder.java:34) ~[graylog.jar:?]
at org.graylog2.bootstrap.CmdLineTool.setupInjector(CmdLineTool.java:530) ~[graylog.jar:?]
at org.graylog2.bootstrap.CmdLineTool.doRun(CmdLineTool.java:317) ~[graylog.jar:?]
... 26 more
please provide the proper steps to avoid this issue and successful upgrade.
This is Out of my knowledge, but what comes into mind id if you are pointing to system java or build in graylog java in your configs.
