Combining Metric
is it possible to combine metrics in a widget? What I want to do is to count unique ip addresses in a stream. In a widget, I can use either card(dst_ip) or count(dst_ip) / sum(), but what I really need is:
count(card(dst_ip)) .
Something close to this is already possible: If I do card() and choose a stacked Bar Chart, I get the value I need, but most of the time, the browser will collapse :slight_smile:
Even better would be a solution to combine two fields before like ‘union’ in SQL:
count(card(union(src_ip, dst_ip)))
Regards
Daniel
If you have two fields one called dstip and the other with called srcip. Yes they can be on the same Widget.
