Cisco logs refuse to index
Some logs coming from Cisco switches got indexed but some others coming from same brand and model Cisco switches are not indexed and dropped
We have Cisco Nexus switches C3548P-10GX some are indexed correctly others have their packet dropped.
tcpdump confirms that packets from both sources arrives on the graylog nodes on port 514
we have local redirection to port 1514 and it works for all of our sources except those switches
though the configuration are the same on both switch:
logging server XX.XX.XX.162
logging timestamp microseconds
logging monitor 7
logging level syslog 6
logging origin-id hostname
some following packets are indexed
some following packets are dropped
Here is the input configuration
  • OS Information:
    RedHat 8.10
    Graylog 5.0.13
What could be the issue on some switch that makes packet to be drop? but not on some others?
It remains mystery to me
Best regards
The first step in troubleshooting would be to change out the syslog input for a raw input and turn off all processing, then start to add things back one at a time.
If the message isnt syslog compliant the input will drop the message.
If the message is processed, but one of the fields is a different data type then it will be rejected when trying to store it. Storing a string in a number field etc.
I have change the Input to Raw/UDP and it changes nothing same sources are indexed and other are not.
I have analyzed the packets with wireshark and realize packets are identical for both sources, so there’s no reason to believe some packets are malformed.
I guess the reason might be somewhere else but maybe not related to graylog itself, we are still investigating, thanks for the tips anyway.
