Hi, New to graylog… got it working for my cisco asa 5508-x with firepower however, it is not working with the intrusion events. (works great for rule events)
I have configured the firepower intrusion policy to do SNMP to my graylog server and to use syslog (just trying to get one or the other working)… In graylog I have 2 inputs, one for SNMP which is using port 162 and one for syslog udp 514. I did use the authbind to allow the ports to be used on my ubuntu box. All the configuration looks right as far as I can tell, just when I generate an intrusion event it shows in the real time monitoring of the Cisco Firepower box, but no logs show up in either of those inputs in graylog.
Graylog out of box doesn’t support SNMP input. Do you use som plugin for it?
Second, check your search and find messages for 1 day, or try Absolute time range. It’s usually problem with timestamp, if device doesn’t send proper syslog message.
Try to run tcpdump on graylog box to check if something received on port 514 udp.
For example use this command, generate intrusion event, and check tcpdump output:
sudo tcpdump -A -n -vv -i ens160 port 514
Note: Change your interface name ens160, if different
But where is that delay coming from? Did you checked if that traffic reach Graylog in time and the delay is produced in Graylog or if that is send with delay from your Firepower?
