CISCO CSR Syslog
Hello Friends,
I am currently testing greylog to syslog for a Cisco CSRV. Can someone help with how this is configured within grey log?
Below is the config on the CSRV:
logging host 10.27.255.4 transport udp port 5149
In Grey log I have completed the following steps:
System > Inputs, select the input type from the drop down box (syslog UDP), and hit “Launch new input”. From here I have entered the following settings:
  • allow_override_date: true
  • bind_address: 0.0.0.0
  • expand_structured_data: false
  • force_rdns: false
  • override_source: empty
  • port: 5149
  • recv_buffer_size: 262144
  • store_full_message: true
The input is showing as ‘running’ however I do not see any data packets from the CSRV at all. Can someone point me in the right direction?
Thanks,
Niall
You might find this blog helpful https://jalogisch.de/2018/working-with-cisco-asa-nexus-on-graylog/
Hi @jan,
Thank you for the quick response.
I have reviewed this document, however this has not resolved the issue. can I test connectivity from the Greylog server to the CSRV? to confirm its an issue on the sender side? Does this functionality exist?
Thanks,
Niall
