My SSL cert expired so I created a new one but kept the old name. Even after restarting the webserver I am having the below two issues:
- Web server front end still using old cert even though I made sure to make sure the new cert was placed in the same location that graylog.conf is pointing to with the same name.
- I am able to connect my servers to collector-sidecar and receive logs with the new cert (I updated the JVM store). I can see my logs show up fine within the Graylog UI but I am still receiving the below errors.
time=“2019-01-10T19:44:02-05:00” level=info msg=“Stopping signal distributor”
time=“2019-01-10T19:44:02-05:00” level=info msg="[filebeat] Stopping"
time=“2019-01-10T19:44:02-05:00” level=info msg="[winlogbeat] Stopping"
time=“2019-01-10T19:45:13-05:00” level=info msg=“Starting signal distributor”
time=“2019-01-10T19:45:13-05:00” level=info msg="[filebeat] Starting (exec driver)"
time=“2019-01-10T19:45:13-05:00” level=info msg="[winlogbeat] Starting (exec driver)"
time=“2019-01-10T19:45:23-05:00” level=info msg="[winlogbeat] Configuration change detected, rewriting configuration file."
time=“2019-01-10T19:45:26-05:00” level=info msg="[winlogbeat] Stopping"
time=“2019-01-10T19:45:26-05:00” level=info msg="[filebeat] Configuration change detected, rewriting configuration file."
time=“2019-01-10T19:45:27-05:00” level=info msg="[filebeat] Stopping"
time=“2019-01-10T19:45:29-05:00” level=info msg="[winlogbeat] Starting (exec driver)"
time=“2019-01-10T19:45:30-05:00” level=info msg="[filebeat] Starting (exec driver)"
time=“2019-01-11T01:03:56-05:00” level=error msg="[RequestConfiguration] Fetching configuration failed: Get https://mcs-graylog:9000/api/plugins/org.graylog.plugins.collector/68641001-530f-494b-88f9-6800eecdb3e7?tags=[“windows”%2C"tacacs"%2C"windows+AD"]: net/http: TLS handshake timeout"
time=“2019-01-11T01:04:16-05:00” level=error msg="[RequestConfiguration] Fetching configuration failed: Get https://mcs-graylog:9000/api/plugins/org.graylog.plugins.collector/68641001-530f-494b-88f9-6800eecdb3e7?tags=[“windows”%2C"tacacs"%2C"windows+AD"]: net/http: TLS handshake timeout"
time=“2019-01-11T01:04:27-05:00” level=error msg="[UpdateRegistration] Failed to report collector status to server: Put https://mcs-graylog:9000/api/plugins/org.graylog.plugins.collector/collectors/68641001-530f-494b-88f9-6800eecdb3e7: EOF"
time=“2019-01-11T01:04:36-05:00” level=error msg="[RequestConfiguration] Fetching configuration failed: Get https://mcs-graylog:9000/api/plugins/org.graylog.plugins.collector/68641001-530f-494b-88f9-6800eecdb3e7?tags=[“windows”%2C"tacacs"%2C"windows+AD"]: net/http: TLS handshake timeout"
time=“2019-01-11T01:04:47-05:00” level=error msg="[UpdateRegistration] Failed to report collector status to server: Put https://mcs-graylog:9000/api/plugins/org.graylog.plugins.collector/collectors/68641001-530f-494b-88f9-6800eecdb3e7: net/http: TLS handshake timeout"
time=“2019-01-11T01:04:56-05:00” level=error msg="[RequestConfiguration] Fetching configuration failed: Get https://mcs-graylog:9000/api/plugins/org.graylog.plugins.collector/68641001-530f-494b-88f9-6800eecdb3e7?tags=[“windows”%2C"tacacs"%2C"windows+AD"]: net/http: TLS handshake timeout"
time=“2019-01-11T01:05:07-05:00” level=error msg="[UpdateRegistration] Failed to report collector status to server: Put https://mcs-graylog:9000/api/plugins/org.graylog.plugins.collector/collectors/68641001-530f-494b-88f9-6800eecdb3e7: net/http: TLS handshake timeout"
time=“2019-01-11T01:05:16-05:00” level=error msg="[RequestConfiguration] Fetching configuration failed: Get https://mcs-graylog:9000/api/plugins/org.graylog.plugins.collector/68641001-530f-494b-88f9-6800eecdb3e7?tags=[“windows”%2C"tacacs"%2C"windows+AD"]: net/http: TLS handshake timeout"
time=“2019-01-11T01:05:27-05:00” level=error msg="[UpdateRegistration] Failed to report collector status to server: Put https://mcs-graylog:9000/api/plugins/org.graylog.plugins.collector/collectors/68641001-530f-494b-88f9-6800eecdb3e7: net/http: TLS handshake timeout"
time=“2019-01-11T01:05:36-05:00” level=error msg="[RequestConfiguration] Fetching configuration failed: Get https://mcs-graylog:9000/api/plugins/org.graylog.plugins.collector/68641001-530f-494b-88f9-6800eecdb3e7?tags=[“windows”%2C"tacacs"%2C"windows+AD"]: net/http: TLS handshake timeout"
time=“2019-01-11T01:05:47-05:00” level=error msg="[UpdateRegistration] Failed to report collector status to server: Put https://mcs-graylog:9000/api/plugins/org.graylog.plugins.collector/collectors/68641001-530f-494b-88f9-6800eecdb3e7: net/http: TLS handshake timeout"
time=“2019-01-11T01:05:56-05:00” level=error msg="[RequestConfiguration] Fetching configuration failed: Get https://mcs-graylog:9000/api/plugins/org.graylog.plugins.collector/68641001-530f-494b-88f9-6800eecdb3e7?tags=[“windows”%2C"tacacs"%2C"windows+AD"]: net/http: TLS handshake timeout"
time=“2019-01-11T01:06:07-05:00” level=error msg="[UpdateRegistration] Failed to report collector status to server: Put https://mcs-graylog:9000/api/plugins/org.graylog.plugins.collector/collectors/68641001-530f-494b-88f9-6800eecdb3e7: net/http: TLS handshake timeout"
time=“2019-01-11T01:06:16-05:00” level=error msg="[RequestConfiguration] Fetching configuration failed: Get https://mcs-graylog:9000/api/plugins/org.graylog.plugins.collector/68641001-530f-494b-88f9-6800eecdb3e7?tags=[“windows”%2C"tacacs"%2C"windows+AD"]: net/http: TLS handshake timeout"
I have already looked at this document. http://docs.graylog.org/en/2.5/pages/configuration/https.html
Anybody ever change out their cert before? If so, what did you have to change to get everything working as it was?
