When I create an Index you can specify the index prefix, but by default it will append _# to the end as it increments. Is it possible to change this to a -# ? I need to make it a hyphen instead of underscore to have another software package look at the same index.
I saw something from 2021 that it may not be possible but wanted to check to see if that is still the case.
