Cannot load graylog web interface from fresh install
sorry been at jury duty last couple days so wasn’t able to look into this.
Opensearch has been running. I understand that 9200 is for opensearch…and 9000 should be the graylog web console. I was just stating that I do get the api from 9200 and 9000 I am not getting anything. It is extremely odd to me the logs seem it is showing it is trying to looking for elastic searchthough. I have completed redone the VM though so no overlap or configuration stuff. When I made the box with elasticsearch before it functioned fine.
Sorry I have been at jury duty so haven’t been able to respond to this timely.
After looking at the logs and graylog is constantly looking for ES this doesseem to be the case. I am not sure where it is defined to use OS vs ES though. I shared logs earlier, but for ease I share them here again with others as well.
is_leader = true
root_timezone = CST6CDT
http_bind_address = 10.100.20.201:9001
rotation_strategy = count
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 0
allow_highlighting = false
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
**cat /graylog/opensearch/config/opensearch.yml ** >>
cluster.name: graylog
path.data: /graylog/opensearch/data
network.host: 0.0.0.0
http.port: 9200
discovery.type: single-node
cat /etc/systemd/system/opensearch.service >>
[Unit]
Description=Opensearch
Documentation=OpenSearch documentation - OpenSearch documentation
Requires=network.target remote-fs.target
After=network.target remote-fs.target
ConditionPathExists=/graylog/opensearch
ConditionPathExists=/graylog/opensearch/data
[Service]
Environment=OPENSEARCH_HOME=/graylog/opensearch
Environment=OPENSEARCH_PATH_CONF=/graylog/opensearch/config
ReadWritePaths=/var/log/opensearch
User=opensearch
Group=opensearch
WorkingDirectory=/graylog/opensearch
ExecStart=/graylog/opensearch/bin/opensearch
LimitNOFILE=65535
LimitNPROC=4096
LimitAS=infinity
LimitFSIZE=infinity
TimeoutStopSec=0
KillSignal=SIGTERM
KillMode=process
SendSIGKILL=no
SuccessExitStatus=143
TimeoutStartSec=180
[Install]
WantedBy=multi-user.target
Just to show services are running >>
I don’t see where the elasticsearch/opensearch peers are defined in your server.conf. It doesn’t look like the full config file. There should be a lot of inline documentation in there that is commented out.
Please send the entire file, rather than the edited version above. Or did you copy it from somewhere else and replace the original contents?
I did notice something in your opensearch.yml though.
The network host should be the IP of the host. You may be able to use the wildcard, but if you don’t have multiple NiCs, there is no need for it.
# GRAYLOG CONFIGURATION FILE
# This is the Graylog configuration file. The file has to use ISO 8859-1/Latin-1 character encoding.
# Characters that cannot be directly represented in this encoding can be written using Unicode escapes
# as defined in https://docs.oracle.com/javase/specs/jls/se8/html/jls-3.html#jls-3.3, using the \u prefix.
# For example, \u002c.
# * Entries are generally expected to be a single line of the form, one of the following:
# propertyName=propertyValue
# propertyName:propertyValue
# * White space that appears between the property name and property value is ignored,
#   so the following are equivalent:
# name=Stephen
# name = Stephen
# * White space at the beginning of the line is also ignored.
# * Lines that start with the comment characters ! or # are ignored. Blank lines are also ignored.
# * The property value is generally terminated by the end of the line. White space following the
#   property value is not ignored, and is treated as part of the property value.
# * A property value can span several lines if each line is terminated by a backslash (‘\’) character.
#   For example:
# targetCities=\
#         Detroit,\
#         Chicago,\
#         Los Angeles
#   This is equivalent to targetCities=Detroit,Chicago,Los Angeles (white space at the beginning of lines is ignored).
# * The characters newline, carriage return, and tab can be inserted with characters \n, \r, and \t, respectively.
# * The backslash character must be escaped as a double backslash. For example:
# path=c:\\docs\\doc1
# If you are running more than one instances of Graylog server you have to select one of these
# instances as leader. The leader will perform some periodical tasks that non-leaders won't perform.
is_leader = true
# The auto-generated node ID will be stored in this file and read after restarts. It is a good idea
# to use an absolute file path here if you are starting Graylog server from init scripts or similar.
# You MUST set a secret to secure/pepper the stored user passwords here. Use at least 64 characters.
# Generate one by using for example: pwgen -N 1 -s 96
# ATTENTION: This value must be the same on all Graylog nodes in the cluster.
# Changing this value after installation will render all user sessions and encrypted values in the database invalid. (e.g. encrypted access tokens)
# You MUST specify a hash password for the root user (which you only need to initially set up the
# system and in case you lose connectivity to your authentication backend)
# This password cannot be changed using the API or via the web interface. If you need to change it,
# modify it in this file.
# Create one by using for example: echo -n yourpassword | shasum -a 256
# and put the resulting hash value into the following line
# Default is empty
#root_email = ""
# Default is UTC
# Set the bin directory here (relative or absolute)
# This directory contains binaries that are used by the Graylog server.
# Default: bin
# Set the data directory here (relative or absolute)
# This directory is used to store Graylog server state.
# Default: data
# HTTP settings
#### HTTP bind address
# Default: 127.0.0.1:9000
http_bind_address = 10.100.20.201:9000
#### HTTP publish URI
# The URI will be published in the cluster discovery APIs, so that other Graylog nodes will be able to find and connect to this Graylog node.
# This configuration setting *must not* contain a wildcard address!
#http_publish_uri = http://192.168.1.1:9000/
#### External Graylog URI
# Default: $http_publish_uri
#http_external_uri =
#### Enable CORS headers for HTTP interface
# This allows browsers to make Cross-Origin requests from any origin.
# This is disabled for security reasons and typically only needed if running graylog
# with a separate server for frontend development.
# Default: false
#http_enable_cors = false
#### Enable GZIP support for HTTP interface
# This compresses API responses and therefore helps to reduce
#http_enable_gzip = false
#http_max_header_size = 8192
# The size of the thread pool used exclusively for serving the HTTP interface.
#http_thread_pool_size = 64
# HTTPS settings
# Default: false
#http_enable_tls = true
# The password to unlock the private key used for securing the HTTP interface.
# If set to "true", Graylog will periodically investigate indices to figure out which fields are used in which streams.
# It will make field list in Graylog interface show only fields used in selected streams, but can decrease system performance,
# especially on systems with great number of streams and fields.
# requires authentication.
# Maximum number of attempts to connect to elasticsearch on boot for the version probe.
# Default: 0, retry indefinitely with the given delay until a connection could be established
#elasticsearch_version_probe_attempts = 5
# Waiting time in between connection attempts for elasticsearch_version_probe_attempts
# Default: 5s
#elasticsearch_version_probe_delay = 5s
# Maximum amount of time to wait for successful connection to Elasticsearch HTTP port.
# Default: 10 Seconds
# (e. g. during search, index creation, or index time-range calculations)
# Default: 60 seconds
# be tore down.
# Default: inf
# Default: 200
#elasticsearch_max_total_connections = 200
# elasticsearch server).
# Default: 20
#elasticsearch_max_total_connections_per_route = 20
# Maximum number of times Graylog will retry failed requests to Elasticsearch.
# Default: 2
elasticsearch_max_retries = 2
# Enable automatic Elasticsearch node discovery through Nodes Info,
# see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster-nodes-info.html
# WARNING: Automatic node discovery does not work if Elasticsearch requires authentication, e. g. with Shield.
# Default: false
#elasticsearch_discovery_enabled = true
# Filter for including/excluding Elasticsearch nodes in discovery according to their custom attributes,
# see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster.html#cluster-nodes
# Default: empty
#elasticsearch_discovery_filter = rack:42
# Default: 30s
# Set the default scheme when connecting to Elasticsearch discovered nodes
# Default: http (available options: http, https)
#elasticsearch_discovery_default_scheme = http
# Default: false
# Enable use of "Expect: 100-continue" Header for Elasticsearch index requests.
# If this is disabled, Graylog cannot properly handle HTTP 413 Request Entity Too Large errors.
# Default: true
#elasticsearch_use_expect_continue = true
# Graylog will use multiple indices to store documents in. You can configure the strategy it uses to determine
# when to rotate the currently active write index.
# It supports multiple rotation strategies, the default being "count":
#   - "count" of messages per index, use elasticsearch_max_docs_per_index below to configure
#   - "size" per index, use elasticsearch_max_size_per_index below to configure
#   - "time" interval between index rotations, use elasticsearch_max_time_per_index to configure
# A strategy may be disabled by specifying the optional enabled_index_rotation_strategies list and excluding that strategy.
#enabled_index_rotation_strategies = count,size,time
# Provides a hard upper limit for the retention period of any index set at configuration time.
# This setting is used to validate the value a user chooses for the maximum number of retained indexes, when configuring
# an index set. However, it is only in effect, when a time-based rotation strategy is chosen.
# If a rotation strategy other than time-based is selected and/or no value is provided for this setting, no upper limit
# for index retention will be enforced. This is also the default.
# max_index_retention_period = P90d
#            This configuration setting is only used on the first start of Graylog. After that,
#            index related settings can be changed in the Graylog web interface on the 'System / Indices' page.
#            Also see https://docs.graylog.org/docs/index-model#index-set-configuration
#  1w  = 1 week
#  1d  = 1 day
#  12h = 12 hours
# Optional upper bound on elasticsearch_max_time_per_index
# elasticsearch_max_write_index_age = 1d
#no_retention = false
# Default: graylog-internal
# be enabled with care. See also: https://docs.graylog.org/docs/query-language
# Default: 1h
# This value should be set lower than elasticsearch_max_total_connections_per_route, otherwise index optimization
# could deplete all the client connections to the search server and block new messages ingestion for prolonged
# periods of time.
# Default: 10
#elasticsearch_index_optimization_jobs = 10
# Mute the logging-output of ES deprecation warnings during REST calls in the ES RestClient
#elasticsearch_mute_deprecation_warnings = true
# Default: 1h
# Time interval to trigger a full refresh of the index field types for all indexes. This will query ES for all indexes
# and populate any missing field type information to the database.
# Default: 5m
#index_field_type_periodical_full_refresh_interval = 5m
# The size of the thread pool in the output buffer processor.
# Default: 3
# Possible types:
#  - yielding
#  - sleeping
#  - blocking
#  - busy_spinning
ring_size = 65536
# Manually stopped inputs are no longer auto-restarted. To re-enable the previous behavior, set auto_restart_inputs to true.
#auto_restart_inputs = true
# Enable the message journal.
# The directory which will be used to store the message journal. The directory must be exclusively used by Graylog and
# ATTENTION:
# disabled if not set.
# messages end up.
# Time in milliseconds after which a detected stale leader node is being rechecked on startup.
#stale_leader_timeout = 2000
#shutdown_timeout = 30000
# MongoDB connection string
# '+'-signs in the username or password need to be replaced by '%2B'
#mongodb_uri = mongodb://grayloguser:secret@localhost:27017,localhost:27018,localhost:27019/graylog?replicaSet=rs01
# DNS Seedlist https://docs.mongodb.com/manual/reference/connection-string/#dns-seedlist-connection-format
#mongodb_uri = mongodb+srv://server.example.org/graylog
# Maximum number of attempts to connect to MongoDB on boot for the version probe.
# Default: 0, retry indefinitely until a connection can be established
#mongodb_version_probe_attempts = 5
# Email transport
#transport_email_enabled = false
#transport_email_hostname = mail.example.com
#transport_email_port = 587
#transport_email_use_auth = true
# Encryption settings
# ATTENTION:
#    Using SMTP with STARTTLS *and* SMTPS at the same time is *not* possible.
# Use SMTP with STARTTLS, see https://en.wikipedia.org/wiki/Opportunistic_TLS
# Use SMTP over SSL (SMTPS), see https://en.wikipedia.org/wiki/SMTPS
# This is deprecated on most SMTP services!
#transport_email_use_ssl = false
# Default: 5s
#http_connect_timeout = 5s
# Default: 10s
#http_read_timeout = 10s
# Default: 10s
#http_write_timeout = 10s
# ATTENTION: If you configure a proxy, make sure to also configure the "http_non_proxy_hosts" option so internal
#            HTTP connections with other nodes does not go through the proxy.
# Examples:
#   - http://proxy.example.com:8123
#   - http://username:password@proxy.example.com:8123
#http_proxy_uri =
# A list of hosts that should be reached directly, bypassing the configured proxy server.
# This is a list of patterns separated by ",". The patterns may start or end with a "*" for wildcards.
# Any host matching one of these patterns will be reached through a direct connection instead of through a proxy.
# Examples:
#   - localhost,127.0.0.1
#   - 10.0.*,*.example.com
#http_non_proxy_hosts =
Did I miss this configuration on the documentation ??
https://go2docs.graylog.org/5-0/downloading_and_installing_graylog/ubuntu_installation.html
(had to delete some of the log as giving error of char limit for post)
You need to point Graylog to your Elasticsearch/Opensearch servers here. ElasticSearch is where Graylog stores/queries messages after its done adjusting them. @joe.gross spotted this in a previous post. Not sure that would keep the interface from loading but things would not work properly without that connection.
Deeply Thanks all -
Just so I kind of understand better context - after pointing it there I was able to get to the admin console. I guess by default it looks at Elasticsearch?(due to what the logs were showing graylog trying to reach out for ES, and when I installed greylog before with ES it seemed to (presumably) load the web login without this.
historically Graylog used Elasticsearch but their licensing changed (among other things) leading to a transition to OpenSearch. The name you see in there like elasticsearch_hosts = is legacy naming that likely has other underling ties to it won’t be updated quickly.
Glad you have it working!
