Can we publish Content pack using API
Hi Team,
Is it possible to remotely add content pack through CLI or over API?
Heyo @blason
Have a look at your API-browser under System -> Nodes.
You’ll find an endpoint called System/Bundles. This is what you’re looking for :slight_smile:
BTW: Anything that you can do with the web UI, you can do via an API since Graylogs Web UI is only depending on Graylogs ReST-API :slight_smile:
Greetings,
Philipp
Awesome buddy!! Thanks a ton :slight_smile:
