Hi Graylog Team,
I have setup local DSV lookup table and its working absolutely properly. However I am unable to create a dashboard using Decorators. neither those are appearing in my search.
So, decorators can not be used in dashboard widget?
Hi Graylog Team,
yes, decorators only change what is visible in the result list - you can’t do a widget with this temporary change of data.
You would need to use the lookup table to add the data permanent to the data if you want to create dashboard widgets with that.
This is confusing!! I mean I configured the look up table and those look tables are used as a decorators.
So, decorators are temporary? How do I make those permanent then?
make use of the lookup table in extractors or the processing pipeline.
I see thanks for the reply.
