Blank Page behind Cloudflare
Overnight, the physical server that hosts my graylog cluster went down. Since bringing it back up, I get a blank page when attempting to access the cluster via Cloudflare Load-balancing.
My setup is as follows:
My setup:
  • OS Information:
    All environments are Debian 12 within a LXD container hosted by PVE
  • Package Version:
    Graylog 5.1.5
    Mongodb 6.0.10
    opensearch 2.9.0
All server.confs are the same with the following difference:
is_leader = true applies to grayserver-1 / 192.168.1.1
is_leader = false applies to grayserver-{2,3} / 192.168.1.{2/3}
and IP/fqdns are charged to match the respective host:
http_bind_address = 192.168.1.1:9000
http_publish_uri = http://192.168.1.1.9000/
http_external_uri = https://grayserver-1.foo.bar/
http_enable_cors = true
Further Info:
So, if I navigated to https://graylog.foo.bar, I get the blank screen.
If I navigate to any of https://grayserver-{1,2,3}.foo.bar, it loads properly.
The server.log for any of the grayserver-{1,2,3} servers only have this recent error (on grayserver-1):
2023-09-26T10:29:49.883-04:00 ERROR [IndexRotationThread] Couldn't point deflector to a new index
java.lang.IllegalStateException: No index size
at org.graylog2.indexer.rotation.strategies.TimeBasedSizeOptimizingStrategy.lambda$shouldRotate$1(TimeBasedSizeOptimizingStrategy.java:81) ~[graylog.jar:?]
at java.util.Optional.orElseThrow(Unknown Source) ~[?:?]
at org.graylog2.indexer.rotation.strategies.TimeBasedSizeOptimizingStrategy.shouldRotate(TimeBasedSizeOptimizingStrategy.java:81) ~[graylog.jar:?]
at org.graylog2.indexer.rotation.strategies.AbstractRotationStrategy.rotate(AbstractRotationStrategy.java:77) ~[graylog.jar:?]
at org.graylog2.periodical.IndexRotationThread.checkForRotation(IndexRotationThread.java:127) ~[graylog.jar:?]
at org.graylog2.periodical.IndexRotationThread.lambda$doRun$0(IndexRotationThread.java:91) ~[graylog.jar:?]
at java.lang.Iterable.forEach(Unknown Source) [?:?]
at org.graylog2.periodical.IndexRotationThread.doRun(IndexRotationThread.java:87) [graylog.jar:?]
at org.graylog2.plugin.periodical.Periodical.run(Periodical.java:99) [graylog.jar:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source) [?:?]
at java.util.concurrent.FutureTask.runAndReset(Unknown Source) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source) [?:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) [?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) [?:?]
at java.lang.Thread.run(Unknown Source) [?:?]
Which I presume is related to a situation that occurred last week wherein I had a separate physical server housing another Opensearch node that was part of the cluster, crash:
The browser throws these errors when navigating to https://graylog.foo.bar:
But no errors when navigating to https://grayserver-{1,2,3}.foo.bar
NOTE: All https is handled by Cloudflare via Cloudflare Tunnel
EDIT: I forgot to add, here is an example of how the Cloudflare tunnel is configured:
EDIT 2: A bit more info, Sidecars appear to be working fine (i.e. Graylog sees them and they are configured to look for https://graylog.foo.bar) however the data is actually sent to an NGINX load balancer that is defined within the configs pushed by the sidecar.
Any help is greatly appreciated; thank you!
One thing that caught my eye is that http_external_uri needs to match the URL you are accessing graylog at via your browser. That means if you access via a load balancer URL, that should be the value configured.
The important concepts for configuring the graylog web interface:
  • http_bind_address
    • specific to what IP/interface graylog server receives incoming connections on
  • http_publish_uri
    • the address to reach the specific graylog node on. This is also used for graylog to communicate both with itself and with other nodes. Typically this should be a valid DNS name of the graylog node
  • http_external_uri
    • The web address in your web browser that you access graylog at. If this is a load balanced address, use that. If you load balance multiple graylog nodes this should not be the DNS name of a specific node but rather the load balanced URL
See also Overview for more info on the topic.
Hope that helps.
That does and I’ll be honest its a concept that has always confused me. That being said, any idea why it would have worked, before? Additionally, if I can only use one http_external_uri that pretty much eliminates the potential of using Cloudflare Load Balancing w/ tunneling
If anyone else has a similar setup and is experiencing a similar issue, I believe I figured out the solution.
Lets assume you have a setup like this:
Load Balancer URL (the one you type into the browser):
Your Cloudflare tunnels are set as follows:
If each server.conf has the above listed as the external_uri ( grayserver-{1,2,3} ) you will get the blank page if navigating to https://graylog.foo.bar. However, you will get the graylog landing page if navigating to any of https://grayserver-{1,2,3}.foo.bar.
HOWEVER, if you add “graylog.foo.bar” as a HTTP Host Header in the Public Hostname Page setting of the tunnels for each grayserver-{1,2,3}.foo.bar, you will be able to resolve https://graylog.foo.bar successfully.
Hope this along with @drewmiranda-gl 's advice helps anyone else with a similar issue!
