Best practice - field mapping
I have a csv file that has descriptions for a field in message. Example messages are
{id_field: cryptic_id1}
{id_field: cryptic_id2}
and the csv file that acts as dictionary:
 cryptic_id1,Readable Description1
 cryptic_id2,Readable Description2
I would like to be able to add the description fields into the message dynamically, so if the cryptic_id is contained in the csv file a translation field would be added to the message.
My first idea was to generate a rule with a script to create a long rule in pipeline with a lot of when conditions and then paste the output in interface.
Unfortunately a rule can only have one ‘when’ conditions and creating a lot of rules would require a lot of clicking.
How would I do it otherwise?
You will be able to use the new lookup tables feature in Graylog 2.3.0 for this:
