Plugin is not reflecting in Graylog Console.
Version:- Graylog v2.4.0
Download the BackupConfig Plugin 1.0.2 and place the .jar file in Graylog plugin directory.
Restart graylog-server
did you checked if the version is working with graylog 2.4?
I’m using Version:- Graylog v2.4.0
Did you checked if the Plugin you try to use is compatible with that Graylog version?
Required Graylog version: 2.1 and later
https://github.com/fbalicchia/graylog-plugin-backup-configuration
Maybe open a bug report in that repository? Just an idea…
Also see:
