Alert events not trigger since graceful shutdown
The incident:
Hi! Since I executed graceful restart in my graylog clúster, alert events stop triggered.
My environment:
3 graylog nodes + 3 elasticsearch nodes, each one of them with RHEL 8.2
Graylog version: 3.2
Elasticsearch version: 6.8
MongoDB version: 4.2
Logs
Evidence of graceful shutdown
Las alert I received (before shutdown).
I don’t believe in coincidences.
I’ve already re open gl-events IndexSet.
Any help will be appreciate.
Hello @ale_sabat
From the first screenshot i see [NO_MASTER], this would be a configuration, network, service issue.
I personal would start to make sure all services ( ES, Mongo & Graylog) are running without errors or warnings.
If all node/service are fine then I would check configruations on all Graylog config file to ensure they are correct
And last, check Firewalls/ SELinux/AppArmor for blocking network connecions.
If all the above is good, then dig in to the log files Elasticsearch/Graylog and MongoDb. and post your finding here if you can.
Here are some post you can check out
