Stream alerts stop working after upgrading to cluster
i’ve just upgraded my installation and switch from one graylog server to 3 clusters members graylog.
But since i’ve done this, my streams alert had stop working. So there is some special config in order to get back online my alerts?
Thank you for helping
From which version to which version did you upgrade?
What’s the complete configuration of all three Graylog nodes?
http://docs.graylog.org/en/2.4/pages/configuration/file_location.html
I’m stayed in version 2.4
Before :
1 graylog server with mongodb
1 cluster elastic search : 3 servers
After:
3 graylog server with mongodb (replica set)
Is it the graylog master which is responsible to trigger alerts?
Slave
is_master = false
Master :
is_master = true
Common conf (except url) :
rest_listen_uri = http://nil-adm.cines.fr:9000/api/
rest_enable_gzip = false
rest_enable_tls = true
rest_tls_cert_file = /etc/graylog/server/ssl/nil.crt
rest_tls_key_file = /etc/graylog/server/ssl/pkcs8-plain.nil.key
web_listen_uri = http://nil-adm.cines.fr:9000/
web_enable_gzip = false
web_enable_tls = true
web_tls_cert_file = /etc/graylog/server/ssl/nil.crt
web_tls_key_file = /etc/graylog/server/ssl/pkcs8-plain.nil.key
elasticsearch_hosts = http://x.y.z.1:9200,http://x.y.z.2:9200,http://x.y.z.3:9200
rotation_strategy = count
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 0
allow_highlighting = false
output_batch_size = 5000
output_flush_interval = 5
processbuffer_processors = 3
outputbuffer_processors = 4
processor_wait_strategy = sleeping
ring_size = 262144
inputbuffer_ring_size = 65536
inputbuffer_processors = 1
message_journal_dir = /mnt/graylog/graylog_journal
message_journal_max_age = 240h
message_journal_max_size = 50gb
mongodb_uri = mongodb://yyy:xxx@x.y.z.129:27017,x.y.z.137:27017,x.y.z.138:27017/graylog?replicaSet=rs_graylog01
transport_email_hostname = localhost
transport_email_port = 25
transport_email_use_tls = false
Just a little precision there is only one slave which serving web ui.
Lionel.
Please post the full configuration of all Graylog nodes and not just what you think the difference is.
Also, make sure that /etc/graylog/server/node-id has a unique content for each Graylog node.
Ok so node-id are unique on each node, and here full graylog configuration :
Master :
is_master = true
password_secret > = XXXXXXXXXXXXXXXXXXXXXXXXXXXXX
root_password_sha2 = XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
root_timezone = Europe/Paris
rest_listen_uri = http://A.B.C.138:9000/api/
rest_enable_tls = false
web_listen_uri = http://A.B.C.138:9000/
web_enable_tls = false
elasticsearch_hosts = http://X.Y.Z.173:9200,http://X.Y.Z.174:9200,http://X.Y.Z.175:9200
ring_size = 262144
message_journal_max_age = 96h
mongodb_uri = mongodb://XXX:YYY@A.B.C.129:27017,A.B.C.137:27017,A.B.C.138:27017/> graylog?replicaSet=rs_graylog01
transport_email_from_email = graylog@FQDN
Salve
is_master = false
rest_listen_uri = http://A.B.C.137:9000/api/
web_listen_uri = http://A.B.C.137:9000/
ring_size = 262144
Slave + Web UI + Web API (backup in load balancer algorithm):
is_master = false
rest_listen_uri = http://nil-adm.FQDN:9000/api/
web_listen_uri = http://nil-adm.FQDN:9000/
processbuffer_processors = 2
outputbuffer_processors = 2
ring_size = 262144
message_journal_max_size = 500gb
What’s in the logs of all Elasticsearch and Graylog nodes?
i tried to trigger an alert in order to have usefull log, and now it work again. So i does not understand.
Is it alert triggered when graylog have lot of message to process in queue?
